what oil drain hoses are you guys using?
Posted: Sun Mar 31, 2013 11:57 am
by vrmmmpshhh
Ive got the car running with the s15 turbo and its great apart from the oil drain line bursting and pissing oil all over the bottom of the engine. what hose are you guys using? i have some gates premoflex high temp oil hose here but after checking online it is only rated at 100c continuous.
Re: what oil drain hoses are you guys using?
Posted: Sun Mar 31, 2013 12:00 pm
by NitroDann
Speed flow fire rated hose with speed flow fire sleeve because that's what the local rod shop sells and it works.
How's it going tuned it yet?
Posted: Sun Mar 31, 2013 12:17 pm
by vrmmmpshhh
i literally drove it 500m before the oil line burst.. with the greddy emanage im seeing 12.0 afr at 8psi
Posted: Sun Mar 31, 2013 12:30 pm
by NitroDann
Cool when's it come on boost? What exhaust?
It shouldn't be under any pressure by the way. Overheating and melting yes bursting no.
Posted: Sun Mar 31, 2013 4:14 pm
by vrmmmpshhh
it was split just under the the top hose clamp and was spraying when i was on boost. exhaust is a cobalt cat back with the factory cat but that will get changed out. i just wanted it running before the end of the holiday period which it is.
Posted: Sun Mar 31, 2013 4:19 pm
by NitroDann
Sounds like the hose clamp cut into it to me without seeing it.
Posted: Sat Apr 06, 2013 1:33 pm
by 4sfed5
Im running a blue goodyear high temp oil hose I think its rated to 120 degrees maybe. Been in for 7 years and its still in great condition
Posted: Fri Apr 19, 2013 10:30 pm
by Sean
Yep - I've put the blue dunlop stuff of 4 or 5 cars to replace aging stock stuff. Always worked fine.
I'd go to the local hose shop (pirtek/enzed etc) and explain what it's for and they'll fix you up.
