So my SE gets engine oil in the Intercooler, throttle body etc when pushing hard on the track. Just a bit, never have to top it up.
It is a well documented issue with MSM Miata's in the US, and its because of the catch Can design and the oil travelling up and through it to the airbox under high G cornering, aided by the suction of the turbo.
Now has any one tried this solution, as I can't seem to find anything on it???
Flyin Miata MSM check valve kit
http://www.flyinmiata.com/index.php?dep ... r=36-90100
Sounds like what I need.
I am not willing to put a 2nd catch can or aftermarket one in, prefer the standard look.
SE Oil in Intercooler, Throttle Body etc
- Luke
2022 BRZ 10AE
2021 GR Yaris
2021 GR Yaris
- NitroDann
Re: SE Oil in Intercooler, Throttle Body etc
Why dont you just leave it. Its designed to work that way.
Luke, Moto East does a check valve kit to stop the oil and the pressurising of the petrol tank
Rob
NitroDann wrote:Why dont you just leave it. Its designed to work that way.
Because if it's sucking oil out of your sump via the return feed then eventually the oil level will drop and the engine will be b0rked.
Some info here .. http://www.mazda-speed.com/forum2/index ... 379.0.html
- NitroDann
Theres no chance it can suck oil out of the sump, it collects oil fumes and condenses them back into liquid and sometimes it spills into the intake system as a fluid rather than gets sucked in as a gas.
If you check your oil it is fine.
All factory cars vent the block this way.
I found this post interesting, but perhaps there were other factors at play ..
millsj wrote:... This system seems to work well until the cars are dríven really hard, specifically on the track. When the car is on track, blow-by pressurizes the oil pan and pushes oil UP the drain line, fills the catch can and then continues to push oil into the intake tract.
When I installed a second catch can between the separator and the intake, I was seeing approximately 8oz+ of oil in the second catch can in a 20 minute session. :shockeyes: Without some way of stopping the oil from being pushed back up the drain line or without a second catch can, all of this oil will then pass through the intercooler..
- NitroDann
I considered that after you posted.
The obvious solution is to remove the drain back and add a slash cut.
- Luke
Flyinmiata sent me the link for the install.
http://www.flyinmiata.com/support/instr ... ve_kit.pdf
Looks easy... with the engine out like they have it.
I have oil lines for the remote oil filter and steering in the way.
Looks like a hoist/pit job to me.
2022 BRZ 10AE
2021 GR Yaris
2021 GR Yaris
Yup i've seen that page and they're now selling the kits with a slightly different (wider) hose that's meant to be easier to install.
If you put the car on stands and remove the drivers side wheel you might be able to get in there ok.
