Page 1 of 2
Gauges & use of the OBDII
Posted: Fri Nov 23, 2012 4:57 pm
by cooper1896
So
I have a modified SE (Mania Stage 1 & 2) that currently has a boost gauge.
I would like to get some more gauges to monitor whats going on, as I am taking the car on the track.
I have herd good things about the use of a PLX kiwi Bluetooth tool + OBDII port transmitting to a tablet device.
I was intending to go down this road as it is a lot cheaper than buying separate gauges.
Does anyone have any experience with these?
Would I be better or with an Apple or Android based tablet?
Are there any significant gauges that the OBDII doesn’t provide data for?
Finally, to complicate this more, as my car runs an adaptronic ecu, can anyone tell me if it the OBDII will still work?
Andrew
Re: Gauges & use of the OBDII
Posted: Fri Nov 23, 2012 5:25 pm
by kenson
Not sure about your ECU, but I use this:
https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en and an Android phone.
Not available on Apple devices.
Posted: Fri Nov 23, 2012 5:54 pm
by Sailor
I'm also playing with Torque Pro...It's looking very good atm on my Nexus7 tablet
Posted: Mon Nov 26, 2012 11:48 am
by dbr
The On Board Diagnostic (OBD) regulations where introduced to standardise the communication requirements for diagnostic tools. This is how these aftermarket devices can be used on a varrietry of vehicles.
The regulations also require a number of tests to be run during the opperation of the car so a warning light can be illuminated if an engine malfunction will cause the exhaust emissions to fail the legal limits. It is unlikely that an aftermarket ECU would be calibrated to opperate the light correctly due to the extensive Emission testing required. Knowing this, the aftermarket ECU supliers usually don't spend their time writing extencive OBD software and a device relying on OBDII probably won't work. Try it before you pay for it.
Posted: Mon Nov 26, 2012 1:43 pm
by Lokiel
I have an an Adaptronic e440, the PLX Kiwi bluetooth module and the Android Torque application.
Boost
Oil Temperature
Oil Pressure
The reported OBDII Intake temperature is useless since the Adaptronic ECU does not pass the reading onto the OEM ECU (reports a fixed value).
The OBDII water temperature is useful since it gives you a real gauge as opposed to the dummy water temperature gauge we have in the car.
For track days I like my Contour GPS camera and overlay the following Torque data onto its video using DashWare:
* RPM
* Engine Load
* Throttle Position
* Water Temperature
If I ever get time, I plan to finish my Adaptronic logger using C++ and Linux on a MK802 mini-computer (about the size of a USB stick) - that'll give me lots of useful information for post-track day analysis and I won't need to use Torque.
See my post here for more details:
http://mx5cartalk.com/forum/viewtopic.php?f=19&t=53529&hilit=Real+world&start=25Torque is a great tool for diagnosing CELs and clearing them so it's something you should buy anyway.
Posted: Mon Nov 26, 2012 2:31 pm
by bootz
It's a real pisser that the OBD does not do oil pressure.
Strange that on the SE the OBD does not receive data for boost.
Boost affects fueling and timing so I would expect it to be registered
Posted: Mon Nov 26, 2012 3:09 pm
by sailaholic
But stock ecu see airflow through the afm, not manifolds pressure (boost) to determine fueling
Posted: Mon Nov 26, 2012 3:28 pm
by Lokiel
sailaholic wrote:But stock ecu see airflow through the afm, not manifolds pressure (boost) to determine fueling
Yup, the MAZDASPEED turbo was implemented as cheaply as possibly (they never even bothered to fit a boost gauge).
Posted: Mon Nov 26, 2012 4:08 pm
by 16bit
where is the plug for the adapter on nb's?
Posted: Mon Nov 26, 2012 5:21 pm
by Lokiel
Remove the interior fuse cover above your right thigh - the socket sits above the fuses.
Posted: Mon Nov 26, 2012 6:20 pm
by kenson
16bit wrote:where is the plug for the adapter on nb's?
Note, not available on all cars. My 2001 NB didn't have it, but my 2004 SE did(does)
Posted: Mon Nov 26, 2012 6:25 pm
by Suspense
It's only NB8C (Sept 2002 build) onwards.
Posted: Mon Nov 26, 2012 7:09 pm
by 16bit
balls
Posted: Wed Nov 28, 2012 12:32 am
by cooper1896
Sounds like OBDII based apps has some
limited uses, thanks for the comments.
Seems so stupid of mazda to have a dummy water temp gauge
There seem to be some pretty cheap OBD2 transmitters (some WiFi some Bluetooth) on ebay. Any reason why I shouldn't get one of those?
something like this
http://www.ebay.com.au/itm/WiFi-WLAN-Wi ... 116wt_1156Also what are CELs?
dbr wrote: It is unlikely that an aftermarket ECU would be calibrated to opperate the light correctly due to the extensive Emission testing required. Knowing this, the aftermarket ECU supliers usually don't spend their time writing extencive OBD software and a device relying on OBDII probably won't work. Try it before you pay for it.
Lokiel, my car has the older Adaptronic e420 edu, can you see any reason that i could't grab the OBD2 data as planned (not that worried about emissions, more the data that you had suggested).
Lokiel wrote:"Are there any significant gauges that the OBDII doesn’t provide data for?"
Boost
Oil Temperature
Oil Pressure
Don't suppose anyone can suggest a cost effective method of getting these gages. (I'll will probably start another thread for that, or do a search)
Posted: Wed Nov 28, 2012 2:01 am
by bootz
cooper1896 wrote:Sounds like OBDII based apps has some
something like this
The Check Engine Light, records that there is an error message i.e. cat failure - can only be interpreted thru OBDII reader.
The Dummy gauge is the Oil Press, SO SO SO ARSE OF MAZDA to do this.
Only reason I would not get a cheapy trans is no on/off switch so you have to remove it when not in use
So the MAF handles the turbo boost fueling, now I am confused.
