Both people posting in this thread with the kit and flash tune have confirmed that the hardware works fine however the cars do not run properly, wont pass emissions, cannot be dríven at WOT safely, and nobody in the country is able to tune the car, they also are illegal, and once out of registration will not be able to be re-registered.
I already said all this didn't I?
And stop saying the cars are fine, they aren't you both just said they don't run right as nobody can tune it, and the Aussie SC kit supplier is using a tune that they didn't confirm worked right and still doesn't and is unable to change it, and somebody has a car for sale because it cannot be registered as its illegal and in his state cannot be engineered and needs to be complianced which does cost tens of thousands of dollars.
neilhr wrote:hey Danny,
I am very new to this and have not used a piggy back at all. But from what I have learnt from TDR Jay is that every NC's tuning is different and really needs to be custom tuned. At least with Jay, he is very easy to contact and the tunes come very quickly. That is shocking that the RX-8 AFR's were so different.
Of course it does when you are asking 50+% variations in fueling and ignition.
Apparently only a fraction of the NC's ECU maps has been reversed engineered thus far. Enough to create a safe tune,if the cars so much as tips into a map that hasnt been changed it isnt safe, and as you said there are dozens and 90% of those havnt been reverse engineered. A safe tune that pulls engine lights on, runs in boost at >13:1 AFR etc? but I think it's uncertain what map the ECU will use at an given time and if that one map has not been adjusted then its definitely not good. This is what happened to the first Sniper/Cosworth tune that blew engines. And the tunes in australia are supplied by dynotronics, as bad a snake oil salesman as FFS
Hopefully with all the logging I am doing I can help Jay to get a good base tune for the Aussie NC's. My car's been flashed 7 times now and I expect a lot more!
I hope so too for everyone involved, I just cannot believe that a kit that risks 10k of damage is being sold for 10k when nobody within 20 thousand kilometres is able to adjust anything, and its obvious that it wasnt tested thoroughly enough to be safe.
I hope that everything is sorted out, however its clear that one tune doesnt fit all, and that means no compliancing in Victoria and none in the other states without IM240's for each car etc. i sincerely hope you guys get it sorted out, however you have to stop recommending a product that has an improper tune, no matter how much you like the guy fitting it, its extremely irresponsible.
