NOOB Question - WOT Noise - high pitch sound?
doro733
Postby doro733 » Mon Jul 23, 2012 4:56 pm
Just had my first autokana day with my "new" 04 NB SE. :NB8B:
On my last couple of runs i noticed a quite (just audible) high pitch noise when under WOT, in second gear. and disappears as soon as you back off.
the sound is not a Mechanical whine.
The sound does not appear under normal driving.
Upon chatting with a few of the other MX5 guys and checking all hoses and fluid levels we could see nothing obviously wrong.
as i am new to Turbo's this is a whole new world of issues!!!
Has anyone heard as similar sound. Any ideas for me to checkout
My car is stock at the moment :)
2004 NB SE
Velocity Red
Re: NOOB Question - WOT Noise - high pitch sound?
Postby NitroDann » Mon Jul 23, 2012 5:00 pm
Either a belt or a dead turbo.
NMX516
Postby NMX516 » Mon Jul 23, 2012 5:06 pm
Wrecked turbo's can make such a noise when the impeller rubs against the inside of the housing, sending metal filings through the engine.... That is fairly extreme though. Get it checked asap - there should be zero shaft play. If there is any shaft play, you potentially have the above problem to some extent.
Could also be a very small air leak somewhere between turbo and throttle body which only makes itself known under full load - small hole in one of the rubber hose sections of that pipework...
doro733
Postby doro733 » Mon Jul 23, 2012 7:14 pm
I have spoken with another owner and he mentioned that it could be the throttle body pipe leaking as he noticed that mine was not seated fully on the TB and the pipe bracket was not on straight.
so i need to check this and then take another SE owner for a drive with me to see what sounds Normal.
2004 NB SE
Velocity Red
Postby NitroDann » Mon Jul 23, 2012 8:34 pm
I dont agree that the turbo needs NO shaft play, but anything more than a millimeter or so in any direction is pushing it.
jerrah
Postby jerrah » Mon Jul 23, 2012 11:12 pm
It's not just the turbo spool noise is it?
1991 MX5
Postby Okibi » Tue Jul 24, 2012 12:58 am
Rich, do any of your gopro videos feature the noise? Stick them up here.
doro733
Postby doro733 » Tue Jul 24, 2012 2:46 am
no too much wind noise to hear any engine sounds, i need to get a mic for the cabin.
2004 NB SE
Velocity Red
vrmmmpshhh
Postby vrmmmpshhh » Tue Jul 24, 2012 1:58 pm
is the wastegate rod tight?
