Injectors.?
psquire45
Injectors.?
Postby psquire45 » Mon Jul 09, 2012 11:08 am
So I'm hunting around looking for a place to get some injectors.
I'm after either 460cc or 550cc that sort of area. Preferably the ones that are plug and play with the standard mx5 fuel rail and Harness
Does any one know a place in Sydney?
Or I've got a mate that works for Bosch. So if any one knows the Bosch part number for the rx8 injectors or the rx7 550cc that would be very useful
Or if any one has a set lying around that they'd like to sell me :)
Paul
1998 NB MX5, AVO turbo kit, Adaptronic plug'n'play, RX8 440cc injectors, Fm Brace, DBA cross drilled brakes, cusco rollbar Pedders springs
zossy1
Re: Injectors.?
Postby zossy1 » Mon Jul 09, 2012 11:49 am
Both RX7 and RX8 injectors are Denso. AFAIK there are no Bosch injectors that have the Denso-style connector that will plug and play with the MX5 injector harness.
Ebay is a good place to look, as is MT.net and miata.net. Look on the US eBay in particular as sets come up all the time and the shipping on injectors is relatively cheap. Make sure you get units that have been cleaned and flow tested and come with new seals.
Otherwise, consider some aftermarket units (like Deatschwerks) with adapter harnesses - they work fine too.
http://miataturbo.wikidot.com/fuel-injectors
psquire45
Re: Injectors.?
Postby psquire45 » Mon Jul 09, 2012 11:59 am
Yeah the research I've been doing backs up the denso info unfortunately, bugger was hoping to get them on the cheap :(
Does any one have any feedback on the ebay ones? I'm just pretty cautious with eBay car bits
Dweezle
Re: Injectors.?
Postby Dweezle » Mon Jul 09, 2012 12:29 pm
I got the rx8 ones from 949 racing.
Was less than $300 delivered i believe.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
vrmmmpshhh
Re: Injectors.?
Postby vrmmmpshhh » Mon Jul 09, 2012 7:28 pm
just keep searching.. i just picked up 6 315cc supra injectors for $50 on ebay. ill get them cleaned and tested and keep 2 spare.
timk
Re: Injectors.?
Postby timk » Mon Jul 09, 2012 7:51 pm
The RX-7 Densos are based on the old school Bosch EV1 design (same style as the stock NA injectors), the RX-8 Densos are based on the EV6 (like NB injectors), and all the "cool kids" run EV14 injectors these days (ID1000 and the like).
Each successor results in better fuel atomisation resulting in smoother idle, more power, hotter girls, etc.
bark
Re: Injectors.?
Postby bark » Mon Jul 09, 2012 8:21 pm
I wouldn't be using rotary injectors in a piston engine. Rotary injectors are designed to shoot long and narrow, pistons are designed to shoot short and wide. You can choose to take it on board or not, just thought worth mentioning.
psquire45
Re: Injectors.?
Postby psquire45 » Mon Jul 09, 2012 10:04 pm
bark wrote:I wouldn't be using rotary injectors in a piston engine. Rotary injectors are designed to shoot long and narrow, pistons are designed to shoot short and wide. You can choose to take it on board or not, just thought worth mentioning.
I've read that too. However I've also read that basically every second person is using them with success :?
saboteur wrote:The RX-7 Densos are based on the old school Bosch EV1 design (same style as the stock NA injectors), the RX-8 Densos are based on the EV6 (like NB injectors), and all the "cool kids" run EV14 injectors these days (ID1000 and the like).
So your saying I want the rx8 ones then so I can be all 8)
Paul
zossy1
Re: Injectors.?
Postby zossy1 » Tue Jul 10, 2012 12:18 am
RX8s will idle better. I much prefer the RX8 injectors to the 550cc RX7 red tops I had on my old car, especially at idle.
They flow better than 460cc too. Closer to 500cc according to my flow test results.
SuperMazdaKart
Re: Injectors.?
Postby SuperMazdaKart » Tue Jul 10, 2012 10:01 am
Try the orange top injectors from a Mazda Familia (323) 1.8L GTR or BG8Z GT-Ae. They are 440cc minimum & go up to 550cc. They are a Group A rally homologation & are fitted with a BP engine using a big turbo (IHI VJ23) from the factory. Those engines made about 156 kilowatts flywheel in standard form.
psquire45
Re: Injectors.?
Postby psquire45 » Tue Jul 10, 2012 10:06 am
Cheers for that zossy I'll have a hunt for some rx8 ones then
I'll have a week or two to hunt around because I'm up to mania thurs to pick up the adaptronic and wide band . They've got a bundle going this month that knocks a couple hundred off the total so that's the priority to take advatange of the savings
jerrah
Re: Injectors.?
Postby jerrah » Tue Jul 10, 2012 4:00 pm
saboteur wrote:..all the "cool kids" run EV14 injectors ... more power, hotter girls, etc.
My EV14 850's arrived yesterday so I'll be selling my RC Racing 550's soon.
1991 MX5
Beelzeboss
Re: Injectors.?
Postby Beelzeboss » Mon Jul 16, 2012 12:48 am
I have a set of 550cc low impedance RX7 injectors with pigtails which I'd let go cheap, I'm also in Sydney if you want to pick them up. Shoot me a PM if you're interested.
Andrew
NA-6 2.5 KL V6
http://barberprecision.com.au/
psquire45
Re: Injectors.?
Postby psquire45 » Tue Jul 17, 2012 8:32 am
Thanks for the offer. Ive ordered a set of rx8 430cc from ebay hopefully they should do the job
