Page 1 of 2
Re: turbocharger td05 20b
Posted: Fri Feb 03, 2012 5:53 pm
by NitroDann
If not a troll. Search.
Questions like that prove how far away from being able to successfully turbo your car.
Posted: Fri Feb 03, 2012 6:32 pm
by maniac
oko0ol wrote: how much horse power will i get at 8 pound boost
All of it
Posted: Fri Feb 03, 2012 8:16 pm
by toppertee
oko0ol wrote:Hi just wondering if a td05 any good for a mx5 and how much horse power will i get at 8 pound boost,i was told that the td05 was bigger than a t28.And i think the turbo is not ball bearing does make a difference.thank you
Best bet would be to post it on miata turbo. They are most helpful, with questions of this type.
Posted: Fri Feb 03, 2012 8:26 pm
by Jeo
toppertee wrote:Best bet would be to post it on miata turbo. They are most helpful, with questions of this type.
Yeah, that will go well.
Posted: Fri Feb 03, 2012 8:31 pm
by NitroDann
Hahahahahaha.
Toppertee, you have no idea !
Posted: Fri Feb 03, 2012 8:41 pm
by toppertee
NitroDann wrote:Hahahahahaha.
Yes I do I'm a long time member!
Posted: Sun Feb 05, 2012 12:47 pm
by sean2
You're making this place about as welcoming as miata.net...
IMHO - That turbo is probably going to prove less than ideal for an MX5 at 8psi...
Posted: Sun Feb 05, 2012 2:25 pm
by 93_Clubman
sean2 wrote:You're making this place about as welcoming as miata.net...
In the land of the blind, the one-eyed man is king.
Posted: Sun Feb 05, 2012 2:59 pm
by Tedsmx5
Jeo wrote:toppertee wrote:Best bet would be to post it on miata turbo. They are most helpful, with questions of this type.
Ask Hustler on miata turbo forum
sorry that's cruel.
Good luck with you search "oko0ol".
Ted
Posted: Thu Feb 09, 2012 9:15 pm
by bark
Mmm a Td05-20g, is this for a 1.6 or 1.8? At 8psi you'd be better off with a smaller turbo, if you're thinking of higher boost it may be an option depending on your end goal. I'm currently running quite a low compression on a 1.6 with a Td05-16g. Once it's re-tuned that turbo will be at it's optimum which will be around 23psi, which should see around 200rwkw. With my low compression and the 16g it can be a bit laggy until you get to around 3200-3500rpm and then it'll begin to wind up. But for me this suits as I putter around a bit as it's my daily and it generally doesn't rev much more than say 3,500rpm. My father-in-law had a Td04-16b on his 1.6 and he had boost down lower and thus the power came on earlier and finished earlier. Just depends what you want in the end.
Posted: Fri Feb 10, 2012 7:46 am
by zossy1
You're right Sean, but so are the others. This is an alarming question coming from someone who is considering adding a snail to their mx5.
It reminds me of that red NA6 on eBay recently. Someone had bought a stainless eBay top mount manifold and DP, a 3071 Chinacharger, a massive FMIC and a bunch of universal intercooler piping and bolted it all on to their 250,000km clapped out NA6 with absolutely no engine management or fuel/timing mods. They then ended up selling it for $3K, kindly noting to potential buyers that it "goes like hell" but "sometimes runs lean" and "will need new injectors".
o.O
Posted: Fri Feb 10, 2012 7:59 am
by sean2
I get that, but why be tools about it? Bark has given a great informative response without the crap, and I'm pretty sure he's done some real world research to back his claims.
It's easy to rubbish an idea, particularly when you've never had hands on experience.
Posted: Fri Feb 10, 2012 9:59 am
by NitroDann
You NEVER build a turbo system around a turbo. NEVER. Maybe around a manifold/dump.
Some people feel that its far better to trash an idea bad quickly because subtle hints that it may be a bad idea, still often leads to stupid decisions.
Its clear based on the first post that OP isnt ready to build a turbo car, And trying to do so is probably going to end up like said ebay na6. So why would we encourage him?
Posted: Fri Feb 10, 2012 11:30 am
by sean2
I agree he's not ready, but there was a time when I wasn't ready too, and thankfully I asked around (not just on here though) and was fortunate to get lots of constructive advice on mx5s and turbo charging in general.
Then when I was ready I made some better decisions that were well informed. I'm always open to offering advice on stuff I've done, and have had a hand in a bunch of reliable turbo 5s and even a few NA ones. My wide band has also been hanging from a few e85 EVOs lately, so while I don't profess to be an expert, Im far from inexperienced.
I'd rather encourage someone to seek more info in the hope they can achieve something, it's a better option (for my mind at least) than just shooting then down.
Thankfully there are lots of easy turbo options these days in bolt on kits any monkey could fit. I started with a basic AVO setup and went though a couple of different engine set ups and countless turbos to get to where I wanted. The benefit to me now is if I build another one I can use that experience to do it easier and cheaper in one go this time.
I've also established a good network of people with far more experience than me who are always helpful too... I'd just prefer to help him get to the point where he is ready and does it right.
Posted: Fri Feb 10, 2012 6:30 pm
by bark
Good feedback Sean, we all started from nowhere once and this forum was (and still is) great for advice/bouncing ideas around. I don't profess to know anymore than anyone else, all I have to give advice on is my experience. If that can help someone else then good!
