Turbo bush or ball
olboy
Turbo bush or ball
Postby olboy » Wed Oct 26, 2011 6:58 pm
How do you tell if a turbo has a bush or ball type bearing
I have a Garrett T28 and it has Garrett AR48 stamped on the front
Olboy
Re: Turbo bush or ball
Postby NitroDann » Wed Oct 26, 2011 7:54 pm
If its a nissan turbo is ball bearing. If it has a built in oil restrictor, its ball bearing.
olboy
Postby olboy » Wed Oct 26, 2011 7:58 pm
Thanks Dann
where would the built in restrictor be
It's an FM kit so I don't think its a nissan
Postby NitroDann » Wed Oct 26, 2011 9:10 pm
Where the oil feed enters the CHRA.
olboy
Postby olboy » Thu Oct 27, 2011 8:51 am
Thanks Dann
That means I have to pull it all off just to see if I have a restrictor
I can see the oil line and the fitting but I can't reach it
It looks like a flared brake line fitting, would that be likley to have a restrictor under it ?
Postby NitroDann » Thu Oct 27, 2011 9:53 am
Only one way to find out :P
Why do you need to know? Also have you posted this question on miataturbo? The FM kit is popular there and you might get an answer quick smart if you post a photo or 2.
olboy
Postby olboy » Thu Oct 27, 2011 11:51 am
I need to know because i am getting oil in the intercooler and I think either the seals in the turbo or no restrictor is the problem
