BEGI Autotrotor Kit - Auto Tensioner
1.6lAutorotor
Postby 1.6lAutorotor » Wed Jul 13, 2011 7:24 pm
Hi All,
Anybody know where I should go for info on how to add an auto tensioner to my SC Kit.
I have tried replacing the belt only lasts a month before you can't tighten it enough.
Thanks
Adam
jerrah
Re: BEGI Autotrotor Kit - Auto Tensioner
Postby jerrah » Thu Jul 14, 2011 9:03 am
Have you tried a shorter belt?
When I use a new belt I adjust it 5 minutes after installing then about a week later and then it doesn't stretch further.
Regarding an autotensioner find an autotensioner from the wrecker and attach it to a plate making sure the alignment is right. I've had no issues with my home-made manual tensioner as long as I used an appropriately short belt.
Are you 4 or 6 rib?
1991 MX5
1.6lAutorotor
Postby 1.6lAutorotor » Thu Jul 14, 2011 10:20 am
6 Rib,
You have to tighten the belt by levering the idle pulley arrangement, then tightening the fixing bolts, there isn't a Tightening screw.
Can I see a picture of your "home made" manual tensioner? maybe i can modify mine in some way.
Any mechanics in the Melbourne (Bayside) area or forum sponsors, anybody would recommend for this type of work?
jerrah
Postby jerrah » Thu Jul 14, 2011 11:40 am
Mine is a modified AC tensioner for the NA6. I can take a photo later.
Can you post a picture of your current tensioner?
What a lot of the UK Mini-SC guys are running are these TR Lane copies of another JRSC tensioner, perhaps you could get something like that to work?
http://www.trlanefabs.co.uk/SUPERCHARGER-PARTS.html
100 Pounds but the plans are available online if you wanted to create one yourself.
1991 MX5
jerrah
Postby jerrah » Thu Jul 14, 2011 11:43 am
1991 MX5
1.6lAutorotor
Postby 1.6lAutorotor » Thu Jul 14, 2011 11:52 am
Wow, thanks for all the great info.
Don't have my car with me today, so can't take a photo,
but My Tension-er doesn't have the adjustment screw (top left of them image you linked). This would make it much easier to tighten.
Thanks Again
Postby 93_Clubman » Thu Jul 14, 2011 3:36 pm
1.6lAutorotor wrote:Any mechanics in the Melbourne (Bayside) area or forum sponsors, anybody would recommend for this type of work?
Dean @ Motorsport Essentials 29E Glenvale Cres, Mulgrave 9562 1005; or
Gerald & Chaz @ Mammi Motors, 10 Industrial Drv, Somerville, 5977 7973.
1.6lAutorotor
Postby 1.6lAutorotor » Fri Jul 15, 2011 10:17 am
This is what my Tensioner looks like. Corky Bell ( designer of the kit ) thinks the pulleys are probably just worn out.
Will find a machine shop to discuss both fitting an automatic tensioner and refinishing the Pulleys.
Thanks for your help.
jerrah
Postby jerrah » Fri Jul 15, 2011 11:45 am
Fitting an automatic tensioner to that would be super easy.
Just make a plate that bolts onto the same places as your existing tensioner then drill some holes in said plate to mount the tensioner. Easy!
I'd try with a shorter belt first. Try a belt that you can only JUST fit over the pulleys when new and you'll have less trouble in my experience. Just go into repco with your existing belt size and ask to try one size lower.
1991 MX5
