mx5 se ecu removal
billybunter
mx5 se ecu removal
Postby billybunter » Sat May 21, 2011 12:06 pm
hi
any-one removed their ecu on the se and where/how do you go about the removal.
thanks graham
mx52nv
Purple Porsche Eater
Re: mx5 se ecu removal
Postby mx52nv » Sat May 21, 2011 1:02 pm
WARNING! Please make spare copies of your key through Mazda (they will need to code it) as you will not be able to make any more copies if the factory PCM is no longer connected. The issue is that the key sends a signal to the factory PCM. Not having the factory PCM will also cause a red light to flash continously on the dash. A WA SE owner with a fully built engine, custom turbo kit and an aftermarket ECU has lost one of his keys and is unable to make any more copies as he cannot return the car back to factory due how far he has gone with his car. Mazda is happy to help code a new key but they require the factory PCM to be connected and the car started. This is simply not an option when you have built engine with a different fuel, ignition setup and alternator.
If you are only planning to remove it temporarily and return it unmolested then ignore my warning. :mrgreen:
All NB ECUs are located in passenger footwell below the carpet and metal cover.
Les
Postby Lokiel » Sat May 21, 2011 10:14 pm
See 2nd post of http://mx5cartalk.com/forum/viewtopic.php?f=57&t=41091&start=75
WARNING: Be careful when removing the cover plate, it's sharp (I got a nasty cut the first time I removed it - now it gets a lot of respect).
billybunter
Postby billybunter » Mon May 23, 2011 11:54 pm
to les and lokiel
thanks for the info
Russellb
RIP Nov 2014
Postby Russellb » Mon May 30, 2011 7:09 pm
mx52nv wrote: A WA SE owner with a fully built engine, custom turbo kit and an aftermarket ECU has lost one of his keys and is unable to make any more copies as he cannot return the car back to factory due how far he has gone with his car. Mazda is happy to help code a new key but they require the factory PCM to be connected and the car started. This is simply not an option when you have built engine with a different fuel, ignition setup and alternator.
Les
Easy FIX
Just get a normal Key cut tell the locksmith you only want the key to unlock the door (IF HE TELL YOU THE KEY IS CODED )
I know this works have don it to the SE Rally Car
My ClubmanRebuild
MX5 SE Rally car is HERE :)
