AVO Turbolink ECU- Need diagram on where to connect
marky210
Postby marky210 » Fri Oct 29, 2010 10:40 am
Would anyone have the AVO wiring diagram on where and how to plug in the Link-Turbolink ECU on a NB8A?
I purchased a new loom ready to plug in from AVO lastyear but they could'nt find the diagram and said it was easily findable on the net :| Been lookin for a while but no luck. :frown:
The loom has got all the plugs on it ready to be plugged in.
Also- Need the diagram on exactly where to tap the sump for the oil return
Any help would be great
Cheers,Mark :D
99 mx5, Brilliant Black with hardtop, cusco f/brace,intake and AVO turbo kit awaiting install.Tien SS coilover kit,BD Rollbar,16x7 Work Meister's!!
Re: AVO Turbolink ECU- Need diagram on where to connect
Postby 93_Clubman » Sat Oct 30, 2010 10:32 am
might be in this as it looks to contain a collection of AVO MX5 docs:
http://www.pdfoo.com/mazda/231-11203-pdf.html
think the file you're after is: miata_a4_small.pdf
also found this install with pics on an '90 model:
http://www.turbomagazine.com/tech/turp_ ... index.html
http://www.turbomagazine.com/tech/turp_ ... to_01.html
Juffa
Postby Juffa » Sat Oct 30, 2010 4:42 pm
Not sure if the AVO turbo kits require the sump to be tapped in a specific place, such as provided by 93_Clubman...but check out the Flyinmiata install guide. It provides some good information.
http://www.flyinmiata.com/support/instr ... turbos.pdf
J.
marky210
Postby marky210 » Sat Oct 30, 2010 5:33 pm
Thanks SO much guys :mrgreen:
Will look through them now and let ya know if its got what i need :D
Emailed AVO and never got anything back off them considering the amount of money ive spent with them :?
Cheers,Mark
marky210
Postby marky210 » Sat Oct 30, 2010 6:13 pm
The AVO Link wont work :( when i try to download it all i get is page not found....
The Flyin miata links are good and will help a bit but really need the info on the Turbolink which the AVO kit used and where exactly it plugs into on the 99 NB8A.
Thanks again for the help :D
Cheers,Mark
Postby 93_Clubman » Sun Oct 31, 2010 12:05 am
Instead of AVO had a look at Link & found this:
G27 - Mazda MX5 1999 Triggers and Ignition
http://www.linkecu.com/support/document ... l-drawings
Turbolink manuals might also help:
http://www.linkecu.com/products/Ancilla ... /TurboLink
