SP boost pressure
Posted: Thu Aug 19, 2010 9:06 am
Here's one for the experts?
On a SP the boost pressure is measured from?
A...waste gate
B...actuator
C...Inlet manifold
I do realise that you get a slightly higher reading straight from the wastegate hence the T-piece mod on some cars (I don't want to go down that path)
So i am contemplating getting the actuator rod replaced.
The car was slightly detuned before i bought it.
Basically i have had the car spun up on a dyno to help locate a BOV low boost issue..(problem solved thanks to the lads at MX5 Plus)
I am not that interested in overall kws just boost pressure at this stage as there as far too many variances in getting maximum hp
According to the mapping my fuel is still very rich which will be the next thing to sort out...(possible piggyback solution)
I am just wanting to help punch up the mid range and i believe that on my car the boost pressure is still a little low.
It's just under 6 for those interested....(measured from the manifold)
...LS1's are just soo much easier to figure out
A...waste gate
B...actuator
C...Inlet manifold
