B6 -> BP throttle wheel swap possible? (Dual throttle body)
jerrah
Postby jerrah » Mon Aug 09, 2010 10:51 pm
I'm going to be using a dual throttle body setup on my supercharged MX5. I've noticed the NA6 throttle body (well at least mine does) has a dual cable pulley already on it, but I will be swapping to a BP throttle body with my conversion.
The BP throttle body has just a single cable wheel on it.
Are these interchangable somehow? The BP wheel seems to be pressed onto a shaft, whereas the B6 has a nut at the wheel end.
1991 MX5
Sean
Re: B6 -> BP throttle wheel swap possible? (Dual throttle bo
Postby Sean » Tue Nov 30, 2010 10:59 pm
jerrah wrote:I'm going to be using a dual throttle body setup on my supercharged MX5. I've noticed the NA6 throttle body (well at least mine does) has a dual cable pulley already on it, but I will be swapping to a BP throttle body with my conversion.
The second one is for cruise control IIRC.
Maybe try finding an NB one with cruise control too - I can't be ure, but I'd suspect that would do the trick.
