What would you like to know?
1. Runs upto 440cc injectors fine.
2. Supports closed loop boost control, suggest running there solenoid as opposed to the OEM or an MBC, controls boost very well.
3. Suggest you leave the 02 clamp in, unless you have the knowledge to fool around with TPS & close/open loop settings in the software.
4. Has wideband adapter, so you can street tune.
If you purchase it from Haltech, you should recieve a wiring diagram & base map for you SE.
Haltech Interceptor
- blackster
Re: Haltech Interceptor
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
