Hi All,
The variable TPS part number listed in searches to replace the 1.6l on off TPS no longer finds a part.
BMW/Bosch automatic TPS (part number 0280120402) including plug/tail.
What i have found is another part BMW/Bosch TPS #0280120406 is still availble +$200 but am not sure if it will fit, or if it is variable?
What have other people done when adding after-market ECU's, or should I be ringing wreckers and not new (repco). The car is waiting for this one part.
Variable TPS for 1.6l
- Learner Driver
- jerrah
Alternatively you could try the NB6 manifold and NA8 throttle body. I'm going through that currently myself.
1991 MX5
- Learner Driver
Thanks for the reply
The throttle body is mounted to the front of a supercharger so I won't need the manifold. Are there any complete throttle bodies that have the same bolt pattern, will an auto model na6 fit? Or should I just get an na8 and change the mounting pattern?
I'll have to ring some Mazda wreckers tomorrow. I want my car back.
- jerrah
If you've not seen already these they might be of interest:
viewtopic.php?f=44&t=24894&hilit=automatic+TPS
viewtopic.php?f=55&t=29665&p=376573&hilit=automatic+TPS#p376573
- SuperMazdaKart
After a standard TPS for 1.6?
I threw out a 1.6 throttle body with the TPS attached into the bin today....
- Learner Driver
Thanks for the offer, but it's about 3 hours too late. The guys at the mx5centre had one and were kind enough to drop it at the mechanics. So I should get the car back tomorrow.
Thanks everybody for the sugestions
Users browsing this forum: No registered users and 17 guests
