Hi again guys
wondering about the dump pipe
i was gonna just go get the local exhaust guy weld up a dump pipe
is there anything i should look out for or should ensure i do , i was going to go for a 2.5 inch to just match up to my mid pipe that has a high flow cat on there already.
and do i just use the same o2 sensor ?
thanks
tim
avo install dump pipe questions
leave the gun.... take the canoli's
Can't really answer on the dump pipe.
On the o2 sensor, the stanard one will be a Narrow Band type. I would suggest getting a Wide Band o2 sensor. This will set you back anywhere from $200 to $800 depending on the brand and display you get. The WB version will provide you with a visual of the A/F ratio and can feed into some ECUs for auto tuning.
Aussie made/Supported ==>> www.wbo2.com
Popular on the big forum ==>> http://www.innovatemotorsports.com/
