How Much Torque are YOU getting?
Posted: Fri Sep 04, 2009 8:06 pm
by blackster
Not many aussie dyno's give ft/lb @ the wheels unless you ask the operator spefically for it, what you usually see is newtons atw. Even if AU members were to give torque in ft/lb; you cant compare that with a US let alone FM rotor dyno, we have different correction factors.
Posted: Sun Sep 06, 2009 11:50 am
by Jeo
Doesn't matter what rpm you are measuring it at, refer back to blackster's post.
Posted: Mon Sep 07, 2009 10:56 pm
by Jeo
No, what I said was re-read blackster's post, specifically the part on...
blackster wrote:Not many aussie dyno's give ft/lb @ the wheels
and
blackster wrote:you cant compare that with a US let alone FM rotor dyno, we have different correction factors.
I have always been told that torque figures on chassis dynos are practically guess work which you would be better off ignoring. Note that I'm only referring to the number attached with it, the curve itself and the point at which said number is derived can be useful.
Therefore my previous statement of
Jeo wrote:Doesn't matter what rpm you are measuring it at, refer back to blackster's post.
is still completely relevant.
Posted: Thu Sep 10, 2009 5:40 pm
by blackster
THE REAL BORIS wrote:HOWEVER, the two modified runs from the FM MSM & SE bare no resemblance.
I know the original differences re dyno, units, temps, operators, etc.
You answered your own question. If by chance those variables mean nothing, have you thought that perhaps FM does 1:1 runs; meaning its done in 5th gear, therefore altering hp & torque?
There is a member on here that posted a formula converting newtons atw to Nm atw, from recollection the power run has to be done 1:1. So again, AU dyno dynamics and mainlain figures are not helpful, as they use 4th gear.
All in seriousness the only way your going to find similar torque figures, is if two different SE's with identical mods use the same dyno. Perhaps you should stop putting so much emphasis on dyno's, there just tuning tools; does your butt dyno feel a difference?
Posted: Sat Sep 19, 2009 7:28 am
by MINX
Heres mine.
But as stated before, the actual numbers vary from dyno to dyno and technician setup.
But the curve should give a reasonable representation.
I dont have a Torque print out
Posted: Tue Sep 29, 2009 10:44 am
by Caffeine
So it turns out after all that different dynos (whether caused by the operator, or conditions, or settings etc) give different results.
If only someone had mentioned that at the start we could have avoided all this bickering...
Posted: Wed Sep 30, 2009 12:21 pm
by bjones
Posted: Wed Sep 30, 2009 12:55 pm
by blackster
Caffeine wrote:So it turns out after all that different dynos (whether caused by the operator, or conditions, or settings etc) give different results.
They did
Posted: Thu Oct 01, 2009 8:07 am
by Caffeine
blackster wrote:Caffeine wrote:So it turns out after all that different dynos (whether caused by the operator, or conditions, or settings etc) give different results.
They did
Hrmmm., written sarcasm seems to be difficult to identify...
Posted: Fri Oct 23, 2009 12:29 pm
by Caffeine
THE REAL BORIS wrote:If only someone (like Minx) had simply supplied information at the start you mean? By doing so, we were able to quantify that Minx had 50% more torque at 3000 rpm than on my two runs (which were 8 months or so apart) hardly within normal tolerances of operator, conditions, etc. etc. etc. If you accept those kind of errors then good luck!
It seems that all that was shown was that your results one one dyno were different to the results on another dyno, and that there was nothing wrong with your car. Did the information supplied by Minx actually provide any of that information? no.
Posted: Wed Nov 11, 2009 7:51 pm
by Novice1
Not an SE, but retune on my NB, 176kw atw 12 psi, 365NM torque at 4500.
Managed 186kw atw on one run, but injector size not quite adequate, car didn't like it.
Cheers Novice1
