im pretty new to the whole mx5 game so go easy on me if im making no sense
anyway i purchased a pretty neat 89 model na with quite a few bells and whistles a few months ago for a fun weekend car and also some track work. so far i have only entered it into the victorian round of the ATC (australian tarmac challenge....formerly dutton rally). it was a ripper of a weeked and the car performed faultlessly the whole time!!.. but i want some more power now (who dosen't?!)
at the moment it has..
-rebuilt engine with wiseco pistons,new rods ACL race bearings, new crank, reco head.
-AVO stage 2 turbo kit
-miata link ecu
anyway i want to do some work to it and want to know a few things before i get started.
so...
how much will the standard AVO exhaust manifold flow? i was going to make a custom one but it looks like an ok piece of gear and have read they flow pretty well?? the only problem i have with it (if it is good enough to stay)is clearance for a decent 3inc dump pipe. even if i cut away the fire wall lip will there be enough room.
also i am going to weld the internal gate and go external (38mm enough?). how would the cast manifold go with this mod? where would it go? or with both of these things i want to do would it be best to build a custom manifold?
another thing is the ecu.
what are the miata links like as an ecu? where can my tuner get the software for it?
oh last one.. injectors..apparently some wrx ones fit? 420cc ..ish? i cold only find the info in the injector chart floationg around but no one had fit them. wouldn't they be quite a good match and cheap and easy to find?
thanks in advance
cheers
kris
