PLS help TURBO NA
Novice1
PLS help TURBO NA
Postby Novice1 » Tue Jun 23, 2009 8:46 pm
Hi:
What sort of aftermarket management system are you running.
Send me a pm and I will give you contact details of someone locally who should be able to help you.
CHeers Novice1
bigdog
King of the kennel
PLS help TURBO NA
Postby bigdog » Tue Jun 23, 2009 8:48 pm
You might want to post your request in the general forum Eunos - I don't think a lot of the guys read this section. Also you're after some fairly specific help, and I don't personally know anyone here with an EMS (I assume this is an ECU brand??), so you may be up against it.
As you're in Brissy I would get in touch with the QLD MX5 club and ask around - the guys up there are very helpful and accomodating.
Good luck!
Novice1
PLS help TURBO NA
Postby Novice1 » Tue Jun 23, 2009 8:49 pm
I, can lend you laptop and cable if needed.
I, presume you have the software for the E.M.S
CHeers Novice1
mx52nv
Purple Porsche Eater
PLS help TURBO NA
Postby mx52nv » Tue Jun 23, 2009 10:04 pm
eunos-roadster wrote:little dissapointed with the lack of support here guys ... i have helped a few ppl on this site and thought it might have been a useful tool to get some things done but no replys is a little slack ....
when i was on the zx fourm they helped all the time ... im not being a smart ass just dissapointed
Firstly, I presume you are looking for someone else other than the authorised dealer in Queensland - KP Performance?
Secondly, have you approached Danny or Richard at your local MX5 Plus to see if they can recommend anyone local?
If all else fails, PM me and I will check who else I know up there with a dyno.
Other than that... just chill mate - we are all here to help and may take a little time to respond but we will respond. :mrgreen:
Les @ MX5 Shop
CT
PLS help TURBO NA
Postby CT » Wed Jun 24, 2009 2:41 pm
Find a local tuner who will do it on a dyno for you otherwise it will never be any good. Perhaps PM some of the QLD racers who will know of such people in the brissy area.
Novice1
PLS help TURBO NA
Postby Novice1 » Tue Jun 30, 2009 6:12 pm
gaz47 wrote:hi eunos
give john or rob at brisbane tunuing a call his number is 33931588
he has the fastest mx5 turbo in aus he should be able to help.
regads
GA
If, you are recommending John at the Gabba, I would say stay as far away from him as you can, unless you like your car thrashed by his mechanics in their lunchbreaks.
Cheers Novice1
