Hello; need a bit of advice on which way to go, Have the option to buy a se turbo kit [ every thing execpt the ECU] or should I go with the AVO kit.
I have a NBa with a lightened flywheel and a button clutch . Would be looking at running low boost to start with [ have to pass emissions and engineer,
NSW Rego], I may go for more later. I use this car for mainly track work. Yes I will be running a piggy bag or stand alone
So the question is which set up gives you the best torque/ power ranges and reliabilitly. Or which do you consider the best option?
thanks; Brett
SE Turbo or AVO kit
- Vehicle: NB8A - Turbo
SE Turbo or AVO kit
AVO is a better option in terms of power and scalability.
The SE kit should be easier to get complianced.
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
SE Turbo or AVO kit
I concur.Okibi wrote:AVO is a better option in terms of power and scalability.
Les @ MX5 Shop
