What ECU are you running?
RG.net
Postby RG.net » Fri Apr 17, 2009 4:59 pm
just curious what the fellow members are using as their ECU, please state whether its a piggy back, or standalone, also what sensors i.e map sensor to delete AFM. a price would be good too :)
cheers.
Juffa
Postby Juffa » Fri Apr 17, 2009 5:13 pm
Mark II Miata link ECU for 1.6l (Made in NZ)
Upgraded with Flyin' Miata chip
Standalone unit, almost plug and play
MAP sensor
I bought it 2nd hand, but they were about USD$1500 new from FM.
Not available new anymore.
Fatty
Postby Fatty » Fri Apr 17, 2009 5:30 pm
Jaycar DFA piggyback. Cheap and cheerful, about $140 inc the hand controller iirc (tho you need to build it yourself, comes in kit form). no additional sensors.
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Fri Apr 17, 2009 9:12 pm
Link G4 Storm.
Full stand alone, plug and play (with supplied harness).
It does so much that most of which I'll probably never use. lol
Check it here...
http://www.linkecu.com/products/engine- ... s/g4-storm
As far as I'm aware, it was the first unit installed in an MX5 (hence the initial teething problems).
Not too sure on price, I ticked the option box with AVO when the kit was installed.
It does it's job I suppose, then again, once any 'high end' ECU is fitted and tuned properly you shouldn't have any problems with them.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
Blue94t
Postby Blue94t » Fri Apr 17, 2009 10:58 pm
I had an EMS dualsport on my BP turbo.
Did the job, power map was great, light throttle loadings left a bit too be desired.
Autronics SMC or SM4 are my preference. I tune stripped down versions of the SMC at work and use them a few times a week. They are a great ecu and awesome value for money. I have supplied a few for good mates and we have had great results.
One mate has one on a Datto rally car, N/A with ITB's and it is brilliant to drive. Another is on a turbo BMW and that is great as well.
I will be using Autronic on my big block ute with the ECU controlling N2O and eventually boost as well.
Jake
Postby 93_Clubman » Sat Apr 18, 2009 12:24 pm
Currently running a Unichip fuel & timing piggyback fitted new & tuned in Dec '04 for $1295. Haven't had any problems at all, but you are limited with what you can do with these things, i.e. not able to remove AFM/ MAF. However, have a standalone Wolf3DV4+ which will do all that I need it to (MAP) when I upgrade.
philz
Wheel guru
Postby philz » Sat Apr 18, 2009 12:48 pm
d-mag wrote:Link G4 Storm.
Check it here...
I always thought you had a Megasquirt.
Postby Jeo » Sat Apr 18, 2009 1:14 pm
No forced induction for me but I am running an Autronic SM4.
The Carco guys did the install for me and I know they use Autronics in all of their FI cars.
I'm assuming you're looking for options for your own turbo setup, but can I suggest finding your tuner and learning what options they can work with first. You may end up with the best ECU this way, but you don't want it if you have to ship the car just to get it tuned do you?
Woo
Vehicle: 10AE - Turbo
Postby Woo » Sat Apr 18, 2009 3:53 pm
Motec M800 full standalone, standard sensors except for 3 bar MAP and additional inlet air temp sensor
Got it cheap at $2800 then $300 for a loom and $150 for the MAP
Tuning so far is $2k and it's far from perfect. Another $1k should see it right, however I'll wait till the exhaust and clutch go in before taking the next step.
Fantastic ECU so many features that actually work well, tuning as with any of them is where the cost is. It also depends of if you want 10/10ths or are happy with 9.5, personally it's all or nothing.
Bazz
Very slightly modified 10AE #2562 ..... one of 149 in Australia :wink:
Race what you brung ..... And hope you brung enough
Blue94t
Postby Blue94t » Sat Apr 18, 2009 11:02 pm
Any ecu is only as good as the tune it holds.
Speak to your tuner and see what he is most comfortable tuning. That is always a good reference.
A crap tune on an M800 will result in a car that drives worse than a perfect tune on an old screwdriver adjustable Motec.
Most aftermarket ECU's available today will work great if the tuner knows his stuff and you are prepared to pay for his time.
So a better question to ask may be who are you using to tune your ECU and what brand is it.
Jake
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Sun Apr 19, 2009 11:44 am
Check it here...
I was just about to fork out for one, but I picked the tuner first and basically let them pick the ECU to suit my requirements.
RG.net
Postby RG.net » Sun Apr 19, 2009 11:04 pm
Blue94t wrote:Any ecu is only as good as the tune it holds.
Jake
no doubt, but i didnt ask this question regarding what i am planning to run, i'm asking it out of curiousity.
Blue94t
Postby Blue94t » Mon Apr 20, 2009 8:28 am
Well come on then, spill it, what ecu are you planning to run?
RG.net
Postby RG.net » Mon Apr 20, 2009 8:38 am
Blue94t wrote:Well come on then, spill it, what ecu are you planning to run?
Its a secret :mrgreen:
still early days for me, but atm i am tossing up between the Haltech, or a microtech. Tuner is pretty good with either one of these puppys, prefference would be a haltech if the price is right.
CT
Postby CT » Mon Apr 20, 2009 2:43 pm
Haltech E8 with wideband
(one of about 30 race cars in QLD and NSW running an E8 - just a brilliant ECU for turbo or NA cars.)
