But according to Mania, if you'd track the car mostly, they'd recommend Exedy Racing Clutch.
wun911 wrote:Is the 'ring gear' the black pointy bits around the edge of the flywheel did you angle grind them off, how much weight did you save?
wun911 wrote:Did flyin miata give you an ACT prolite flywheel with the ACT clutch pack? Looks like this with lots of speed holes...
I'm just wondering because I'm thinking of installing one; what's it like to drive is it more noizy or difficult when daily driving?
mx52nv wrote:Personally I have gone through every single version of the Exedy clutches (from the normal HD to the HDCB and whatever else they have) over the last 10 years.
Next time around, once the spare BP motor is built, it will be the OS Giken twin plate for me.
No more messing about.
As I mentioned before, I have tried every type of Exedy clutch available and it just so happens that the HDCB is the one in MX52NV now. I fitted it in early 2008 and it is barely gripping now.Daz wrote:Anybody tried this, I am getting one next week !
http://www.exedy.com.au/CushionButtonClutchKit.aspx
You have PM!d-mag wrote:What's an OS Giken twin plate worth Les?
