Post your turbo / supercharged setup
A quick list of modifications, current power produced and an under bonnet shot.
- timk
No bites? I'll start then:
Previous car:
1989 MX-5 1600
Jackson Racing M45 supercharger
MegaSquirt PNP
330cc injectors
Jackson Racing 10psi pulley
Not sure about power as the clutch couldn't hold it all!
Current car:
2004 MX-5 SE
Cooling Pro intercooler
New intercooler:
Previous car:
1989 MX-5 1600
MegaSquirt PNP
330cc injectors
Current car:
2004 MX-5 SE
New intercooler:
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
Okibi (Dave),
I think having this section is invaluable as many MX5s are either turbo or supercharged using aftermarket/custom kits or are Mazda Motorsports/factory built SP/SEs. Hopefully this section starts pooling together a wealth of information specific for Australian MX5 owners.
As for the thread topic, I am sure people here are sick of this car already so this will be the final time I post the old girl's "stats" and "under skirt" pics
Engine modifications - copy & pasted from garage as I am lazy
B6T bottom end, HKS adj cam gear, AVO manifold, HKS GT2535 turbo, custom intercooler & piping, 550cc injectors, Bosch 044 fuel pump, custom surge tank, Malpassi fuel regulator & gauge, braided hoses, fuel & oil lines, polished intake plenum & modified cam cover, Blitz BOV, Autronics SMC, custom 2.5" straight through exhaust & droopy tip, Top Gun leads, NGK plugs, Cusco oil catch tank, GReddy Air Diversion Plate, oil & radiator caps & a custom radiator core.
Current power
On daily fuel map running 1 bar/15psi boost will be 175 rwkw or 235 rwhp (from memory).
At the track, switching to a different fuel map running 1.4 bar or 20psi boost gets 229rwkw or 307 rwhp.
All this from that little 1.6 litre
All dyno runs were on a Dyno Dynamics in Shoot Out Mode.
Click here for dyno sheet
Under bonnet shot - apologies about the condition, I have not had time to clean my engine in almost a year now
Engine was put together in 1999-2000 and apart from regular oil changes, has done close to 20,000kms over the last 8 years without skipping a beat
But I have a brand new factory floor BP head and block on the engine stand that I will building very soon
Current power
- blackster
04" MX5 SE
Engine mods
Mazdaspeed AEM CAI, SMB exhaust system, Cooling Pro IC, 450cc injectors, GFB Mach 1 recirculation valve, OG 02 clamp, BEGi TB inlet, Haltech Interceptor & boost solenoid
Under bonnet shot
Current Power
169.5rwkw
Dyno sheet here
Engine mods
Under bonnet shot
Current Power
169.5rwkw
Dyno sheet here
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- SuperMazdaKart
Although I don't have an MX-5 currently, spose I'll still post some details as the info might come in handy to others, maybe for a engine swap or the like.
http://www.mx5cartalk.com/phpBB-3.0.2/viewtopic.php?t=33954
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
1991 NA 1.6 with custom bolt on - did the work myself with assistance.
TD04 on SS manifold
RX7 TMIC mounted as FMIC with custom SS pipework
1.8 injectors on home modded dual feed fuel rail
OlderGuy O2 Clamp
Manual boost control
GReddy Emanage Blue
HKS 264 inlet with adjustable cam timing and regrind exhaust
Rerouted coolant path - enters at front of motor and exits at rear (as per Mazda Familiar)
Stocihmeter, oil temp gauge and boost on A-pillar
2 core steel radiator
4.1 1.8l torsen rearend
Soon to be upgraded clutch - currently Exceede HD clutch - std master/slave cylinder.
DBA slotted rotors, with Bendix Ultimate pads - std 1.6 brake booster/lines
Custom 2.5 inch SS exhaust
Running about 8 pounds boost (although peaks at 10 on highway under load) and somewhere in the order of 120rwkw. According to Jules' buttdyno and driving experience when I lent it to him last year it gave the SPs a good run for their money
TD04 on SS manifold
OlderGuy O2 Clamp
GReddy Emanage Blue
Last edited by Uncle Arthur on Sun Nov 23, 2008 10:23 pm, edited 2 times in total.
- Sean
Here is my "old" car, engine bay pic is terrible, but there was nothing particularly aethestic about the engine bay anyhow, built it to drive it rather than to show off how shiney my turbo was... Pic shows the new manifold with external gate etc sitting in the bay too. Ended up selling the car with the AVO set-up.
B6T bottom end, MX5 head, sump etc, standard spec Mazda headgasket.
Braided Oil feedline by Link hose.
AVO manifold, Garret GT series turbo.
Tyger built ceramic coated dump, mid and rear exhaust (:P)
AVO intercooler pipes & frontmount intercooler (painted black for stealth)
440cc injectors, walbro pump, home made dual feed rail (ended up swapping back to stock rail and 370cc injectors.
Internally "cleaned" head - Not ported, just removed casting marks etc. Matched to intake manifold.
Microtech LT series ECU
Bigger ADRAD radiator
NGK "V" plugs
Will dig up the dyno sheet, but made approx 280hp on high boost on pump fuel, 240ish on lower boost with small injectors etc.
Ran a high 12sec quarter on street tyres and open diff
NGK "V" plugs
Boost gauge
GFB BOV
Begi TBE
FM MBC
FM DP & Exhaust
2nd. Catch Can
AEM Inlet
FM Intercooler
Zeitronix WB
RC 310cc Injectors
OEM Boost Cut Bypass
GFB "Turbo Fuse" Boost Cut
FM O2 Clamp
GFB BOV
Begi TBE
FM MBC
FM DP & Exhaust
2nd. Catch Can
AEM Inlet
FM Intercooler
Zeitronix WB
RC 310cc Injectors
FM O2 Clamp
Last edited by THE REAL BORIS on Tue Sep 22, 2009 5:36 pm, edited 6 times in total.
- Vehicle: NA6 - Turbo
Rebuilt B6 with B6T rods, B6T pistons (lower comp 7.8:1), ARP head studs, Greddy Td05-16g kit (comprising of Td05-16g turbo, external wastegate, bov, and SUS manifold), Mazda Familia injectors (black top), MSPNP, IAT sensor, GM Boost Solenoid, ceramic coatings (turbo, wastegate and whole front pipe), intercooler (70mm thick) and K&N air filter. Tuned at 17psi with 150rwkw.
- mx52nv
- Vehicle: Non MX-5
Hey Bark,
See here for Terry's dyno sheet and engine pic.
Terry is running the same kit as you and similiar bottom end.
At less boost (15psi/1bar), he got 173 rwkw on a Dyno Dynamics in Shoot Out Mode.
What type of dyno and other details do you have for the run?
Were you in 4th gear (1:1 ratio on the 5 speed g/box)?
Do you have the factory fuel pump or something better?
Were the Familia injectors close to full duty cycle?
What is the 'dump' pipe and exhaust diameter?
Hope you are not feeling interrogated
I was just trying to find out where the difference went
Here is my old setup.
Car is a 1994 Clubman.
Stock 1.8 motor
320HP T28 Turbo on AVO manifold
front mount
Kevlar heavy duty clutch
RC 370cc injectors
Custom Piping
EMS dual sport computer with handset
Oil catch can
Aluminium radiator by Mr.Enforcer
2.5" stainless steel Exhaust
Fidanza Aluminium Flywheel
High Volume fuel pump
165 RWKW on 15psi
Ran a 12.9 1/4 on crappy street tyres
New setup should make more power and heaps more torque.
Stock 1.8 motor
front mount
RC 370cc injectors
Custom Piping
Oil catch can
165 RWKW on 15psi
- RobH
Hey Jake,
I don't ever remember seeing your engine that clean You sure that is photo of under your bonnet?
Silver SP - KAAZ LSD, Enkei Rims, PSS9's and Project Mu Caliper upgrade kit.
RobH,
Yeah mate, that is my engine, I just didn't own the car at that time so the previous owner was keeping it clean.
Clean motors don't go faster, anyway it wasn't really dirty, it just wasn't shiny like yours.
Jake
Jake
- mx52nv
- Vehicle: Non MX-5
WOAH!!! 12.9 second quarter mile on street tyresBlue94t wrote:Ran a 12.9 1/4 on crappy street tyres
Very nice
What is the new set up may I ask?
- Novice1
Mx5 98 NB.
Garrett T28 turbo.
Intercooler
2.5inch Magnaflow exhaust from Cat Back
500cc injectors
Lightened flywheel
1400 lb pressure clutch, 780 standard I believe
Loch stewart CAI.
Short shifter
Tighe 805 camshaft with cam wheels, soon to be re-calibrated.
Aftermarket radiator
Torsen 3:9
Bosch aftermarket fuel pump
Haltech E8
E-boost controller.
163kw ATW on Mazfix dyno at 12 psi , still running too rich however, further tuning to follow, stay tuned.
Cheers Novice1
Just an update on my car 16th Dec 08. Valve clearances adjusted for turbo setup.
Retune: 168.2kw atw at 12 psi
Will post up dyno later.
Cheers Novice1
Garrett T28 turbo.
Intercooler
500cc injectors
Lightened flywheel
Loch stewart CAI.
Short shifter
Torsen 3:9
Haltech E8
E-boost controller.
Cheers Novice1
Cheers Novice1
