Page 1 of 5
NA6 Turbo Adelaide Update
Posted: Fri Feb 15, 2008 9:03 pm
by bark
All, just a quick update on the progress of my turbo project...
I have it booked in Monday to have the MSPNP tuned. I have found a tuner in Adelaide whom actually tunes according to the combustion in the cylinders rather than with an AFR to ensure that I will pass the IM240 test at Regency Park. According to the tuner you can have an acceptable AFR but if the chemical mix is wrong then I'll fail the IM240 test, something I was not previously aware of!
I had taken the car to a different tuner but they weren't up to the task. Car is running ok on a very basic map that MS has generated by me adding in just a few constants such as injector size, cc of the engine, etc... It runs ok up to about 3,500 to 4,000rpm anything over this and the engine begins to cough, splurt and carry on.
Once the car is tuned I'll post a bit of a write up as well as some pic's to share my learnings with you all.
Posted: Fri Feb 15, 2008 9:32 pm
by yarnmx5
fingers crossed
Posted: Tue Feb 19, 2008 2:21 am
by zoomzoom
Do a few logs and tune using analyze in megalogviewer, you will get a pretty decent tune on it so its doesn't cough and carry on until you get it tuned.
Posted: Tue Feb 19, 2008 7:05 am
by StanTheMan
Now why did i think it was impossible to attach a turbo id SA?????
I was seriously under the impression it was next to impossible or even illegal.
can you enlighten me?
or was it because a few years back a member made such a fuss that I thought it was impossible.
Posted: Tue Feb 19, 2008 11:01 am
by yarnmx5
not impossible.....just lengthy and expensive with no guarantees.
Posted: Tue Feb 19, 2008 9:38 pm
by bark
I submitted an application listing my mod's and spoke to them on the phone re what I planned to do. At the end of the day as long as the vehicle passes an IM240 test it is legal... So now I have an approved application to modify which has just been extended another 12 months.
Once tuned I will be taking it down to get passed on the IM240.
I don't think it has been too much of an expensive exercise. The tune is going to cost me somewhere between $500 to $2,000 which includes an RG240 test (which is $500 alone, but once the vehicle passes this it will pass the IM240). The RG240 test is the same test (an IM240) that Regency will require in order to pass the vehicle. The only difference in the two tests is that the regency equipment is certified and the RG240 test equipment isn't certified.
Posted: Tue Feb 19, 2008 9:49 pm
by SuperMazdaKart
legal turbo conversion in adelaide? i'll believe when i see it. keep up the work though
gosh, looks like i'll be the underdog of the Adelaide drivers here for quite some time...
Posted: Wed Feb 20, 2008 8:36 am
by Lucky_Luke
I was wondering what had happened to this project bark, i remember getting a few PMs and posts regarding your project ages ago!
good to see its still happening!!
When i was going through the rigmoral regency told me an engineers report was a must also as well as emissions testing, and said i had to use one of the engineers off their list.
You heard anything like that bark?
L.
Posted: Wed Feb 20, 2008 8:57 pm
by bark
Luke, no engineers report required. They stipulated that I had to upgrade my brakes (to the later model ones) which I have done and as long as I pass emissions its a done deal (so I'm led to believe).
It has been a 12 month project, the longest part was collecting all of the necessary bits but this was hamstrung somewhat by the bank balance!
Anyone know of who owns a black turbo'd NA6/8 in Adelaide? I saw/heard one some 4-5 months ago...
Posted: Fri Apr 18, 2008 9:44 pm
by bark
Ok latest update - 18/4/08
Since my last post I blew the top tank of my radiator (plastic had fractures which blew) and I have added a sard rising rate regulator.
In order to be able to tune for emissions I have had to re-install my std 230cc injectors as well as my standard fuel regulator. I dropped in today and the car is just about setup for a cold start to meet emissions.
Next step after finalising the cold start will be get the emissions right for a warm engine...
Once cold and warm maps are set I'll be taking the car to regency to pass. Once passed I will return the car to the dyno, re-install larger injectors and rising rate reg and the have it tuned for power. I will need to purchase a larger fuel pump.
For those of you who wish to build a turbo engine from an NA be prepared to pay for tuning time - an emission tune will cost from $1,500 to $2,500 plus regency fee of $495. This is no cheap exercise, I am now committed and want to see this through.
I would have been better off buying a std turbo car and tweaking that, however I lurve my little mx5 - I just underestimated the expense involved as well as the time to meet emissions.
Posted: Sat Apr 19, 2008 1:29 am
by SuperMazdaKart
glad it's you doing all this work, not me
Posted: Sat Apr 19, 2008 12:17 pm
by bark
Bell's Automotive (located Main North Rd, Blair Athol) is doing the emissions tuning for me. Stephen came recommended from Regency and he has the 'know how' as well as the equipment - he is very knowledgeable re emissions.
Posted: Sat Apr 19, 2008 1:36 pm
by bark
It's a hyrbid essentially... I bought the greddy td05-16g kit from spike in WA. This kit came with the td05 turbo, SUS manifold, external blow off valve and some 330cc injectors.
I bought a 2nd hand B6 engine and rebuilt it. Whilst rebuilding I put in ARP head studs, B6T rods and pistons (lower compression 7.8:1). Everything else is pretty much standard (engine wise).
So I guess it started as a \"base kit\" but has then evolved. I had to get a dump pipe made up as well as a return BOV pipe and an air intake pipe. The AFM has been removed. It has an intercooler and I had to get piping made up for this too.
I'm getting the feeling you're embarking on a turbo project also?
Posted: Mon Apr 21, 2008 6:28 pm
by bark
tick4d, you can buy an SP/SE that is already turbo and then you can modify to your hearts content without the need for emissions testing. At the end of the day, the dollars spent may end up being equal... Probably the way to go in my opinion!
Posted: Thu Apr 24, 2008 2:03 am
by Sean
bark wrote:tick4d, you can buy an SP/SE that is already turbo and then you can modify to your hearts content without the need for emissions testing. At the end of the day, the dollars spent may end up being equal... Probably the way to go in my opinion!
Not so sure on that. Any roadgoing vehicle can be sent to pass the IM240 test, even a brand new falcodore (if your local authorities dont like you).
Changing ANY part of the car that effects emissions potentially voids it's ADR compliance, meaning you really need to get it certified. I know here in NSW engineers have recently been advised they are not to certify front mount intercoolers without the relevant (IM240) emissions testing. All states need to comply to ADR 37-00 (from memory) for emissions, regardless of the certification protocol.
