Budget NA6 supercharge build
wade
Re: Budget NA6 supercharge build
Postby wade » Fri Feb 20, 2015 11:37 am
Yeah I've been worried about the wiring for the fans melting due to the heat.
speed
Postby speed » Fri Feb 20, 2015 6:00 pm
wade wrote:Syd....where are you?
Lugarno. I have a 2nd hand innovative wideband that I could lend you.
speed
Postby speed » Fri Feb 20, 2015 6:08 pm
It's a while away but I may offer you my stock SE cooler and one side of the piping.
Also happy to tack your pipes up to get welded by someone more experienced then me or just get a stock SE pipe from IC to TB, the same as what I'm using.
As crazy as it sounds, I want to see what I can get from the stock cooler before I rip it out and go for a wider unit.
Had to justify the purchase and have a bit of a play with my welder :)
wade
Postby wade » Sat Feb 21, 2015 11:57 am
Pm'd
wade
Postby wade » Wed Feb 25, 2015 5:12 pm
So the FMIC arrived today thanks to a member on here :-D
I took the bumper off (what a PITA those top nuts are) and found this underneath
I'm assuming it's some sort of support structure for the bumper.
Q: is it necessary ??
Looks like a weight saving of a couple of kg's :-)
Nevyn72
Postby Nevyn72 » Wed Feb 25, 2015 5:16 pm
wade wrote:I'm assuming it's some sort of support structure for the bumper.
Well that is the actual bumper, the bit you took off is only a dress cover as such....
You could remove it but you wouldn't actually have much in the way of front end crash protection anymore. :|
Postby hks_kansei » Wed Feb 25, 2015 5:19 pm
AS above, that's the actual bumper, the outer bit is just a cover to look pretty.
as for removing it, just leave it. It's there to help either you or the car survive an accident.
speed
Postby speed » Wed Feb 25, 2015 5:30 pm
wade wrote:So the FMIC arrived today thanks to a member on here :-D
Haha, now you know why I left mine on there. When I go for a bigger IC I will have no choice. This weekend is out for me but the following weekend I hope to finish my install and start playing with the MS.
wade
Postby wade » Wed Feb 25, 2015 5:35 pm
Sweet you can take me for a spin when I get back from Japan :-)
speed
Postby speed » Wed Feb 25, 2015 6:26 pm
wade wrote:Sweet you can take me for a spin when I get back from Japan :-)
What the... Ooh parts direct to the suit case :) enjoy!!!
wade
Postby wade » Wed Feb 25, 2015 6:48 pm
Yep.... Going to go to that parts supermarket that the MCM boys go to.
Got my international license today and would love to hire a 86 for a couple of days but I'm struggling to find anywhere in Tokyo :-(
wade
Postby wade » Sat Feb 28, 2015 7:11 pm
So I put the intercooler on.
It all just Bolted up with a bit of patience and a couple of new silicone pieces and clamps.
Spent 15 mins chasing leaks and then took it for a test drive
Here is the vid ..... Complete with a failed handbrakey at the end .....lol
http://youtu.be/MaksYR0eDK8
No more pinging !!!!!
There are some idle control issues and some belt slip though.
So can I tune the second throttle body to sort the idle ?
Does anyone know the best old school way to tune the car ? Especially in combo with the adj Fuel pressure reg ....
Do I just advance it slowly a degree at a time until it starts to ping and then back it off ?
Or do I just set it at 6-7 degrees and not bother ...?
Also the idle screw doesn't seem to do sh*t anymore..... What's that about ?
Paulus
Postby Paulus » Mon Mar 02, 2015 8:39 am
wade wrote:So I put the intercooler on.
Just on idle - you've plumbed the ICV into your intake? where exactly? it needs to be pre everything, post air filter for the ICV to still have any effect.
If you've plumbed post first TB, then the idle valve has nothing to work with - it needs to be hooked upto ambient, if you adjust the first preSC TB to be slightly open at idle, then you'll have enough air to work with.
One thing to be aware of is ICVs have a habit of leaking boost- so it would be wise to install a 1-way check valve to your ICV.
Good luck!
nice welds btw- far better than my solution.
Paul
td05-16g, megasquirt, custom zorst, msdroid tablet etc
wade
Postby wade » Wed Mar 04, 2015 8:18 pm
I'm not sure I understand......the ICV is plumbed in approx where it was originally, pipe runs from the intake (post intercooler) to the TB bolted to the manifold
the first pre SC TB is a little open, but may need a little more.
wish I could take credit for the welds......but I believe that Nitro Dann did the work
Paulus
Postby Paulus » Wed Mar 04, 2015 10:33 pm
Good point about factory inlet. I can assume that somehow the old afm kept enough airflow to allow the icv to get enough air.
As a test you could run it to ambiant and see if idle returns and the screw does have an effect.
I ran it to ambiant for idle control, but I don't think that is legal??
Actually just thinking about this your ecu controls idle.. Still got the AFM? That links to the ecu for idle control afaik
Scrap the above- I think it's an ecu/afm issue
Users browsing this forum: No registered users and 80 guests
