Cosworth supercharger for the NC
zombie
Re: Cosworth supercharger for the NC
Postby zombie » Fri Nov 12, 2010 11:36 pm
Sailor wrote:Hey Matt,
Does your NC2 have the oil cooler as std?
Can't decide if I want the Mazda OEM type or a proper finned one.
I kinda made the assumption it does, since they were standard elsewhere from 2008 on - however as I have learned the hard way recently, there are lots of differences between markets, even ones that make no sense.
will have to ask my workshop next time I'm there as I wouldn't know what an oil cooler looked like if it bit me in the proverbial :oops:
Previous MX-5s:
Innocent Blue NB8A 10th Anniversary Edition
Stormy Blue NC2 Cosworth Edition
Sailor
Postby Sailor » Sat Nov 13, 2010 10:17 am
OK, Oil cooler is attached just aboce the oil filter via a sandwich plate.
There are a couple of water hoses that run forward and up to interconnect with the cooling system.
It's actually a heat exchanger.
Rob
Sailor
Postby Sailor » Thu Nov 18, 2010 8:15 pm
A little more to ponder.
After a chat with Col at Ricol, I've decided to fit a thermostatic oil cooler sandwich plate and put a conventional radiator style oil cooler instead of the heat exchanger style.
We are both concerned that the cooling system will be under enough stress in Oz summers as is evident from some of the posts coming out of USA.
Good news is that there is now a big ally radiator available from Flyin Miata if required.
Might be a little crowded under the front with the intercooler as well...
Rob
Postby orx626 » Thu Nov 18, 2010 8:38 pm
Sailor wrote:Good news is that there is now a big ally radiator available from Flyin Miata if required.
One thing to keep on top of Sailor is the balance between core thickness and FPI (Fins per Inch)...a thicker core doesn't necessarily mean a higher heat transfer to the ambient air. If you maintain FPI and increase the core thickness, the ambient air flow pressure drop across the core will increase and thus reduce the cooling airflow across it. This is further affected by the fitment of other cores in front of it. I'm sure you'll get it sorted just keep this in mind. I'd look at ensuring your getting as much airflow through the core... ie. minimise the opportunity for air to bypass it.
Sailor
Postby Sailor » Thu Nov 18, 2010 10:48 pm
Thanks for reminding me Danny, I'll keep that in mind.
I have considered the oil cooler install under the front guard if necessary.
BTW I'm chasing a section of wiring loom with the ECU plugs on it to make a plug in adaptor for the Xede so I don't need to hack into the wiring.
Any help gratefully accepted
Rob
CoffeeBoss
suntory
Postby CoffeeBoss » Tue Jan 11, 2011 9:43 am
Hey Matt, you're getting the Cosworth internals, right?
Some inside info on such on Moto IQ which you might find interesting (they built a hybrid MZR/DISI engine for an ex. Panoz Le Mans car).
While Cosworth makes one of the finest pistons in the world, the factories also seem to put everything second to F1. The Mazda MZR pistons are made on the same machines by the same machinists as pistons for the CA2010 F1 engines.
zombie
Postby zombie » Tue Jan 11, 2011 11:49 pm
Thanks Matt! Yes, complete Cosworth internals (pistons, rods, cams, rod bearings, valve springs.) The pistons are works of art! Also, the comment I got from the mechanic was that the Cosworth conrods look much more "substantial" (stronger) than the factory forged (NC2) rods, so I'm glad I got those too.
I wish I had more of an update on my car, but every time I think "only a couple more days" something else happens and I lose another week, or two. Right now am waiting on a replacement v-belt from the U.S ... (don't ask :evil: )
I miss my car :NC:
Previous MX-5s:
Sailor
Postby Sailor » Fri Jan 14, 2011 6:30 pm
Hi Matt,
Wat did you do about an ECU?
I´ve installed the Xede on the still std car and after an initial glitch it´s working well.
Rob
zombie
Postby zombie » Wed Jan 19, 2011 9:38 pm
Hi Rob
Adaptronic e420c is installed and working well :mrgreen:
A few more hours of fine tuning required (mainly cold start etc) and I may actually get my car back soon so I can start running in the new engine! only 11 months after starting this project...
More news will follow!
Previous MX-5s:
XMX555
Postby XMX555 » Thu Jan 20, 2011 12:10 pm
Yippie :lol: :D 8) Matt is on the road!!! :mrgreen:
noticed you changed tack and now have gone for a seperate engine ECU, assume the Mazda ECU now only controls ABS, etc.?
looking forward to seeing it in the flesh, maybe our 6 February Cruise?
Aart
"Without the Roof the Sky's the Limt"
zombie
Postby zombie » Fri Jan 21, 2011 12:50 am
I'm not sure I can make it on the 6th, but assuming nothing goes wrong, it will be at Dome Vic Park on Saturday :mrgreen:
Yes, the Mazda ECU controls everything except ignition and fuel. ABS, DCS/TCS, Cruise control etc work great.
I've got a 3800rpm limiter on while I'm running in the new engine and boy that comes up quick, even at half throttle :shock: :D
Previous MX-5s:
Sailor
Postby Sailor » Wed Jan 26, 2011 1:44 pm
report PLEASE!!
Rob
zombie
Postby zombie » Wed Jan 26, 2011 2:36 pm
All is well :mrgreen:
Still running in the engine, enjoying cruising around roofless again. I want to do around 2000km before doing the final tune. I'm nearly halfway there :D
It hunts a bit at idle, mostly due to the slightly aggressive cams, but it usually settles down. Other than that I have no problems to report. The next couple of weeks will be interesting :mrgreen:
Previous MX-5s:
greenMachine
Postby greenMachine » Thu Jan 27, 2011 11:44 pm
I have long believed this 'PEMS' or parallel EMS is the way to go for the NC. The only reservation I held was the Mazda EMS throwing a wobbly when some of the sensors it expects were off-line, or data outside its expected(required) parameters. Was this an issue for you?
:mrgreen:
zombie
Postby zombie » Sat Jan 29, 2011 12:08 am
I had roadstersport headers installed at the same time, and as a result my O2 sensors are currently not connected - giving me 3 codes.
P0037 O2 bank 1 sensor 2 low voltage - this one results in a MIL (Malfunction Indicator Lamp / check engine light)
P0031 O2 bank 1 sensor 1 low voltage
P0140 bank 1 sensor 2 no activity
If I clear the codes with my OBD2 reader the engine light does not come back on until I next start the car. If I don't clear the codes the car does not behave any different anyway, so for short trips I don't bother.
The roadstersport instructions suggest relocating the O2 sensors into the midpipe to avoid these codes - and I was going to do that, but I have this suspicion that if I do so, the Mazda ECU is going to attempt to adjust the short and long term "fuel trims" to account for the difference between the AFR it expects to see, and the AFR it actually sees - because it is no longer in control.
This would most likely result in having it throw codes anyway, so I may as well leave it as it is, it's not doing any harm.
Previous MX-5s:
