Dave's SE - REBORN
beavis
Re: Dave's Disasters
Postby beavis » Sun Jun 21, 2015 3:35 pm
davekmoore wrote:Plugs sooty because it's running stoopid rich. It needs a tune.
Plugs are so cheap i dont know why you would use second hand ones.
How have you gotten this far and it still needs a tune?
davekmoore
Postby davekmoore » Sun Jun 21, 2015 4:37 pm
No-one local has any correct temp plugs with removable top nuts to fit the COP boots, so used an old set of IK24s and ordered an new set of IK22s.
Yup, put off the tune pending maybe putting a proper turbo on it. Might not be doing that for a while though. Also don't trust the original tuner and haven't yet heard enough or consistent enough recommendations for the right tuner locally.
beavis
Postby beavis » Sun Jun 21, 2015 4:47 pm
davekmoore
Postby davekmoore » Sun Jun 21, 2015 5:13 pm
Contact name (Nick?)?
beavis
Postby beavis » Sun Jun 21, 2015 7:54 pm
Trent Hewitson.
davekmoore
Postby davekmoore » Tue Jun 23, 2015 9:24 pm
Nick Thursday, Trent shortly thereafter. Hopefully these'll be two more to put on the list of people who've done great work on my car.
lightyear
Infinity & Beyond
Postby lightyear » Tue Jun 23, 2015 9:43 pm
Nick can sort pretty much any issue. He can do everything from bog less body work, to engine rebuilds.
davekmoore
Postby davekmoore » Tue Jun 23, 2015 10:16 pm
GOOD news:
Sooo, firstly I've hopefully found the right guy to sort the mechanicals, and the right tuner. Then I discover that although they're a bit of a drive from home, they're right next to each other and work with each other all the time. That's pretty handy.
Then I buy some parts which the seller agrees to deliver to me. Then discover he's in the same suburb as the tuner and mechanic and he'll pick me up from there when I drop the car off and drive me home.
Don't you just love it when a plan comes together?
Roadrunner
coyotes after you
Postby Roadrunner » Tue Jun 23, 2015 11:01 pm
That's excellent! Fingers crossed it all works out for you
MeepMeep
davekmoore
Postby davekmoore » Wed Jun 24, 2015 8:59 pm
Found the coolant leak today. Water inlet pipe to turbo. Sorted.
Couple of weeks ago discovered bad oil leak (again) from the dreadfully badly designed turbo oil return pipe. Replaced with high temp flexy pipe. Sorted.
Hopefully we'll no longer have puddles, or steam, or smoke, or smoke screens.
speed
Postby speed » Fri Jun 26, 2015 12:29 pm
Glad things are finally going your way
davekmoore
Postby davekmoore » Fri Jun 26, 2015 7:34 pm
speed wrote:Glad things are finally going your way
If only!
A further disastrous (potentially engine destroying) issue was discovered today.
Will update when sorted.
This car is now officially making me ill.
Postby Magpie » Fri Jun 26, 2015 7:50 pm
I hate to ask, so will wait for the update...
Postby KevGoat » Fri Jun 26, 2015 8:14 pm
Oh no ...... :frown:
davekmoore
Postby davekmoore » Fri Jun 26, 2015 8:34 pm
But yes. I'm finally considering giving up. There's only so much of this you can take.
