Magpie wrote:From memory you need to tap F11. Ring Jason at Plus and ask how to connect
Is this Automotive Plus?
davekmoore wrote:ECU does not show up as a drive on the computer though. Neither F11 nor any other F button changes any of this.
Magpie wrote:I wish I was at home and I could connect and help out. My PS1000 has a USB cable and not a serial cable, however I have a laptop at home that has a serial port as sometimes the USB to serial do not work, the Innovate uses serial connectors to programme.
From memory I plug the USB cable into the computer, power the car, start the software and then click connect. Is the other end of the cable plugged into the PS1000 (silly question I know), from memory it is a D type USB. Try unistalling the software (and deleting the directory) and reinstalling.
davekmoore wrote:Do I need to also stand on one leg and face any particular direction?
Magpie wrote:From memory I plug the USB cable into the computer, power the car, start the software and then click connect. Is the other end of the cable plugged into the PS1000 (silly question I know), from memory it is a D type USB. Try unistalling the software (and deleting the directory) and reinstalling.
Magpie wrote:I'm not sure if the Haltech USB cable is proprietary, mine is left permanently connected to the ECU. Did your previous tuner leave the cable?
bear2230 wrote:The Haltech forum is painfully slow but you will get what you need in time. There should be a Haltech ECU manager icon on your laptop after installing software. Open icon. Plug usb cable into laptop and from drop down menu in ECU manager click file and then connect or F5. Once your in you won't have all the icons like the video you have to set that up but after playing for an hour or so you will be an expert. From there you will have all the settings down the left side of the page and you can open them all and adjust parameters as you like. Stay away from all the fuel settings.That is where you can detonate things. Leave that to the tuner, but the idle, cold start, alternator control settings,ect, you can happily play with and you will feel what adjusting these parameters does while your sitting in the car. There is a info/help menu on the right of the screen that tells you exactly what range is recommended whenever you select a setting. It really is very interesting and you should learn how to do this because taking your car to a tuner to adjust idle up by 100 rmp will drive you nuts. Give me a call if you like Dave, Scooby is 10 feet from where I watch telly and I can connect up in 2 mins. Richard.
