MX5 mania turbo build
anastasic81
Re: RE: Re: RE: Re: RE: Re: RE: Re: MX5 mania turbo build
Postby anastasic81 » Sat Jun 10, 2017 8:11 am
speed wrote:
anastasic81 wrote:MX5 mania put in new plugs and tried switching up coils, not sure if the leads were changed. They gapped the plugs but not sure to what.
The unusual thing is it does one power run then starts playing up. Let it rest for a while and it does it again.
Ecu was build buy a gentleman in Vic. Given the circumstances he has been helpful. He is sending out another ecu just to rule out. He said it may be the coil drivers on the ecu but i wanted to know if anyone else has something similar to ensure we have everything covered off
Sent from my Pixel XL using Tapatalk
I'd say that mania would have everything covered.
Is great that another ecu is being sent.
Just spit balling here but since it happens when attempting to raise the boost, could be map sensor, boost control or injector drivers as mentioned.
Failing that possibly a wiring gremlin.
The new ecu should rule out all of the above except the wiring, unless it is a boost setting but again, suspect mania would be all over it.
Fingers crossed the problem is fixed with the ecu :)
That's what I'm hoping. Fingers crossed the new ecu fixes.
If not I'll mention the wiring. But I hope it is the ecu because post this, not sure where else to look.
Thanks
bear2230
Postby bear2230 » Sat Jun 10, 2017 8:09 pm
You need to take it to some one who is an expert with MS.
ND has has a lot of experience and would be well worth the trip up the coast.
jko
Postby jko » Mon Jun 12, 2017 1:19 pm
Is mania doing the tune with MS3?
anastasic81
Postby anastasic81 » Tue Jun 13, 2017 9:17 am
bear2230 wrote:You need to take it to some one who is an expert with MS.
Gentleman that built me the Megasquirt was referred by ND. See how we go with the replacement ecu.
anastasic81
jko wrote:Is mania doing the tune with MS3?
Yes, there was a base tune.
wasp47
Postby wasp47 » Wed Jun 14, 2017 8:39 am
I know how you feel, all the emotional input, not to mention $'ss, and the bloody thing doesn't go :evil: Takes all the fun out of it.
Steven
StanTheMan
Postby StanTheMan » Wed Jun 14, 2017 9:26 am
second that......
speed
Postby speed » Wed Jun 14, 2017 11:59 am
Third that... had issues with boost control above wastegate pressure and needed new firmware and also a wiring issue.
anastasic81
Postby anastasic81 » Fri Jun 16, 2017 10:58 pm
speed wrote:Third that... had issues with boost control above wastegate pressure and needed new firmware and also a wiring issue.
All fixed, picked up this afternoon. It was a dud ecu...
162kw at the wheels. Kept it conservative for track.
So quick
speed
Postby speed » Fri Jun 16, 2017 11:48 pm
Good work. You're gonna love it!
StanTheMan
Postby StanTheMan » Sat Jun 17, 2017 8:17 am
You must be stoked :mrgreen:
anastasic81
Postby anastasic81 » Sat Jun 17, 2017 8:53 am
Yes, totally different car. Now to see how it tests around Marulan
Postby NitroDann » Sat Jun 17, 2017 5:51 pm
Awesome build dude. I love seeing basic turbo mx5 setups kicking ass.
anastasic81
Postby anastasic81 » Sat Jun 17, 2017 5:54 pm
NitroDann wrote:Awesome build dude. I love seeing basic turbo mx5 setups kicking ass.
Thanks Dann, your manifold and dump pipe were a great fit!!!!!
Postby NitroDann » Sat Jun 17, 2017 6:28 pm
Hopefully see you at the track soon!
