NitroDann wrote:As I understand these aren't knock limited and its not a Turbo, you can't just crank the boost until it is knock limited to take advantage of alcohol. The issue is that they are conrod limited. So you want more torque in an even manner. In the case of these blown cars they drop off up top pretty hard so for me the answer is clearly cams.
Thanks Dan.
Waiting on response fom Mike Moto East re options.
Friend with Kraftwerks s/c is running stock internals, 14 psi and 249 hp atw.
Mike has tuned Mx5,s in the states standard internals to a max of 14 psi.
My car currently 8 psi. I am thinking 10-11 psi max.
Novice1
