davekmoore wrote:Recommendations for a Haltech and MX5 tuner nearest to Mornington Vic who properly understands both?
Dan & Daz @ Road Track Rally, 10 Fiveways Blvd, Keysborough, 9798 5944, <http://www.roadtrackrally.com.au/>
gslender wrote:...also, is the idle problems when running on e85 or regardless when running normal PULP etc... ???
93_Clubman wrote:davekmoore wrote:Recommendations for a Haltech and MX5 tuner nearest to Mornington Vic who properly understands both?
sailaholic wrote:Dave also might depend on if he's talking at speed or in traffic. I would think a bonnet lift WOULD work in traffic as it give an escape for the hot air as there is no high pressure zone at the windscreen.
Either way I think you made the right decision.
Magpie wrote:Bruce I have an attractive GV bonnet that has a vent just behind the radiator. However I run the risk of a defect in QLD as it is made of fibreglass.
Here is my GV Bonnet
Not mine but another GV NA
GV NB Bonnet
gslender wrote:Dave, would seem counter productive to spend time money trying to reduce engine temps when the car is not moving. Get the idle fixed by getting a tuner who knows how to adjust the ECU to cope.
Have you contacted Haltech?
rascal wrote:93_Clubman wrote:davekmoore wrote:Recommendations for a Haltech and MX5 tuner nearest to Mornington Vic who properly understands both?
Dan doesn't work there anymore.
Not sure where he's gone to...
davekmoore wrote:It'll be great if the tune can be made to properly cope with 70 degree under bonnet temps so the car will idle with those temps. However, as far as I can tell from the interweb, higher intake temps reduce power. Research also shows this would be especially true when the turbo is under-sized like my OEM IHI. That's why it seems also worth getting the under-bonnet hence also intake temps down.
