MegaSquirt tune in Perth?
wydra
Vehicle: NB8A - Turbo
Re: MegaSquirt tune in Perth?
Postby wydra » Tue Aug 21, 2012 9:46 pm
Hey guys,
What are other people using as the boost control output?
http://www.diyautotune.com/diypnp/docs/ ... tputs.html
From what I can tell most people use PA0 but with the 99-00 MX5 this is used for the cooling fans.
I am also running Sequential Injection, am i right in thinking because I am using this I cant use PT6 or PT7?
The 99-00 MX5 also has a flyback diode in place for the IAC output and this is jumpered to the loom for the original IAC valve.
Am I out of outputs and unable to use Boost control via the MS?
NB8A - GT2560R, DIYPNP MS2
zoom zoom boom
wydra
Postby wydra » Wed Aug 22, 2012 2:43 pm
If anyone cares or has the same question, answer I got from DIYautotune:
"I would use PA0 for the boost control and use either WLED or ALED for the fans instead."
As ALED is already used for VICS it leaves WLED available.
I will move the fans over to WLED and boost control off PA0.
zoom zoom boom
gslender
Postby gslender » Wed Aug 22, 2012 3:27 pm
I've emailed you some guides on how to do the AC idle up and other features.
Figured now is the time to rewire things if you are doing the boost stuff.
Just yell out if it doesn't make sense or you need help.
G
wydra
Postby wydra » Wed Aug 22, 2012 9:54 pm
Car has started and runs!!!
At first it was cranking but not firing, after a few minutes I noticed I couldn’t hear the fuel pump so changed the MS fuel pump output from 4N to 4P and she fired up. Took it for a couple of gentle laps around the block at it drives pretty good for a base tune.
The things I can see that I need to sort out.
1. the Tacho isn’t working in the car (in Tuner Studio it is working fine)
2. the Immobiliser light on the dash board keeps flashing
3. Tuner Studio is saying "Map Sample Error!" down on the bottom right.
The other next thing I need to do is build the Alternator Voltage reg and incorporate this into the system.
zoom zoom boom
mrpham
Postby mrpham » Wed Aug 22, 2012 10:00 pm
Awesome stuff mate! Must be an awesome feeling to get it running :D
Current Forum Specials!
timk
Postby timk » Wed Aug 22, 2012 10:38 pm
Good stuff! 8)
gslender
Postby gslender » Wed Aug 22, 2012 11:04 pm
wydra wrote: Tuner Studio is saying "Map Sample Error!" down on the bottom right.
Email me a log and ya tune. Gslender at gmail dot com
g
Postby Okibi » Thu Aug 23, 2012 12:44 am
So awesome how helpful you guys are. :mrgreen:
wydra
Postby wydra » Thu Aug 23, 2012 1:22 am
Cheers guys, yep very pleased it has started :) now just need to iron out all the little things then...... BOOST!
G,
I'm running the 3.2.1release and the base map DIYautotune released.
http://www.diyautotune.com/diypnp/apps/ ... 8bp-mt.zip
Now it has started I'll flick it over to 3.3 alpha v2.5 and get it back up and running again.
I'll have bit of a play with it and if I am still getting he error i'll take you up on your offer and get you to have a look.
zoom zoom boom
Postby Okibi » Fri Aug 24, 2012 8:19 pm
http://www.diyautotune.com/catalog/mega ... p-521.html
MS2 PNP for the 99-00 NB, tempted to get one too.
wydra
Postby wydra » Sun Aug 26, 2012 10:01 pm
Ok tacho is now working.
I cant do much more until my wideband o2 is delivered (should be this week) and I need to build the alternator voltage reg circuit (just waiting on some of the harder to get transistors to be delivered).
Has anyone used the VE Analyse Live in Tuner Studio? Is it worth paying the $50 and registering the software to get this functionality?
zoom zoom boom
gslender
Postby gslender » Mon Aug 27, 2012 7:06 am
wydra wrote:Has anyone used the VE Analyse Live in Tuner Studio? Is it worth paying the $50 and registering the software to get this functionality?
Yes and Yes!
G
wydra
Postby wydra » Wed Aug 29, 2012 2:03 am
TunerStudio registered!
My wideband O2 has arrived as well.
Just need to get it along with the boost gauge and a-pillar mount all fitted and the voltage regulator finished (still waiting on delivery of some of the components) and I can start tuning.
zoom zoom boom
gslender
Postby gslender » Wed Aug 29, 2012 8:37 am
Just emailed you a zip of the very latest goodness in MS2 - this new release sports the fancy new MS3 style menus and dialogs (much better arrangement of similar functions etc).
I've also included my known working tune that you'll need to adjust for fuel injectors, timing and outputs - overall it should start in cold and have a good stable idle, and the AFR and spark tables are safe start for a solid tune.
G
wydra
Postby wydra » Wed Aug 29, 2012 1:26 pm
Cheers G,
As soon as I get all the hardware finsihed off I'll get the firmware and sorftware sorted out.
Quick question, with your mods and better idle management, do i have to use a processor input/output for the aircond? The reason I ask is I am starting to get rather tight with my input/outputs as I have sequential injection, boost control, VICS control, radiator Fan control.
I also wanted a dash mounted toggle switch to have a high/low boost setting.
Is this all going to be able to fit?
zoom zoom boom
