Questions. 1.8 head gasket. pistons.
Re: Questions. 1.8 head gasket. pistons.
Postby NitroDann » Wed Jul 04, 2012 11:26 pm
go 9:1 or close.
there you go :)
alexpav
Postby alexpav » Wed Jul 04, 2012 11:37 pm
Woo ok measuring the bores on the block I got the order the pistons then the headaches woohoo thanks for the input all
WILDCARD BITCHESSSS
jerrah
Postby jerrah » Fri Jul 06, 2012 8:04 am
I found the T28 spools fairly quickly but only seems to make 5psi (unless I have a leak somewhere) on the stock actuator.
5psi is fine until I get my TPS issue sorted!
1991 MX5
alexpav
Postby alexpav » Fri Jul 06, 2012 3:34 pm
Selling T28....t25 is enough :) need the money to spend on pistons haha
if i use 9:1 ish how will this go if i decide to take the turbo gear off and run it standard again??
What is compression ratio of standard na8?
WILDCARD BITCHESSSS
Postby NitroDann » Fri Jul 06, 2012 4:16 pm
Nonononono!
The T28 isnt about more power.
Its ball bearing also. Its a better turbo in every way. Keep it. Better spool, better torque, better drivability, better everything.
alexpav
Postby alexpav » Fri Jul 06, 2012 4:25 pm
haha i know i know but its worth more than the T25 to sell (and to replace if ever needed), ive spent wayyy more than i wanted and I havent even started doing any work yet! ( i should have just bought shadowruns complete kit!)
anyways...you can buy it if you want :D
9:1 pistons will be ok withuot the turbo bolted on?
WILDCARD BITCHESSSS
sailaholic
Postby sailaholic » Fri Jul 06, 2012 4:40 pm
I think na8 was only 9.5 std. So will just be a bit slower
bear2230
Postby bear2230 » Fri Jul 06, 2012 9:26 pm
I was tossing up between these:
http://www.frsport.com/index.php?target ... t_id=26648
and
http://www.frsport.com/index.php?target ... t_id=26642
but ended up with what Daniel wanted to use. Arias 9:1. Mania liked supertech 8.6:1 though and when they quoted me for the rebuild that is what Dave recommended.
Richard
Postby NitroDann » Fri Jul 06, 2012 10:12 pm
+1 supertechs, based on all advice from people who I know and trust.
alexpav
Postby alexpav » Fri Jul 06, 2012 11:25 pm
Thank you all for advice!
So I think it is going to be either the supertechs or the CP pistons.
Supertechs if my new block measures to be 83.5mm and if it measures up at 83mm I will be going the CP's.
Again, thank you for all your advice, im sure I will be asking many more questions once I start the build!
SO many things to bold onto this car ahhh :?
I can't stop buying things! turbo related and other randoms bits completely unrelated!
Ah well, the next time i drive this car it will be a unique machine!! :D
WILDCARD BITCHESSSS
alexpav
Postby alexpav » Fri Jul 06, 2012 11:27 pm
Im obviously not going to bold things on to the car, i will bolt them on though! hehehe
Thanks again guys!
WILDCARD BITCHESSSS
