Advise on Adaptronic for an SP
Re: Advise on Adaptronic for an SP
Postby Hammer » Wed Nov 30, 2011 9:52 am
Hi Richard
Ping "Benny" (aka George) from this forum. He's had this modification on his SP for years now.
I've taken it for a drive and it's smooth as silk throughout the rev range. Where my SP would normally jerk and complain if I flutter the throttle around 3-5k rpm, George's SP will happily hover around that spot all day.
He's also added an electronic boost controller under the dash, allowing him to change the boost from a normal 8psi to 15psi (I think). According to George, this is handy when an HSV or FPV pulls alongside at traffic lights. :)
According to David (@ Mania), the new Adaptronic is much smaller and a quicker plug and play (piggyback) unit, making it simpler to connect than before. I too am planning to add this improvement to my SP, I'm just saving the dosh.
bear2230
Postby bear2230 » Wed Nov 30, 2011 10:47 am
Hi Allan,
That’s great. I can sense a GB coming up shortly. Better not give anyone pressies for Christmas and save your bikkies.
I’m trying to meet up with Benny before Christmas but I’m swamped ATM...
Locutus
Postby Locutus » Wed Nov 30, 2011 8:55 pm
can the new adaptronic do anything that the latest megasquirt can't? i like the idea of running an ECU that i built myself.
or is the adaptronic a better option because tuners are more familiar with it?
i'm not just stirring - i will likely be going to an aftermarket ECU for mine in the future, although i can't justify the cost to jump in on the group buy at the moment.
Postby NitroDann » Wed Nov 30, 2011 10:02 pm
No it cannot. Im not sure if alternator control is currently included in MS3, but if not just buy saboteur a 6 pack and he can make you the circuit. :)
Also the MS does HEAPS more little things if you wanted to.
timk
Postby timk » Mon Dec 05, 2011 11:15 am
Locutus wrote:can the new adaptronic do anything that the latest megasquirt can't? i like the idea of running an ECU that i built myself.
It has idle up options for when the air con kicks in which makes the car much more liveable if it is a daily. I think gslender has written a firmware modification to do this on the MegaSquirt II though.
