Post your turbo / supercharged setup
Postby orx626 » Mon Jan 26, 2009 10:17 pm
OMX-596
JR M45 Hotside Kit.
7 psi pulley...we think
Megasquirt PNP & Innovate LC-1
Big G
Postby Big G » Tue Jan 27, 2009 12:24 am
Nice instal Danny!...Good job you had one to practice on 8)
Any plans for an intercooler?
Geoff
Growing old disgracefully in Queensland
Founder of Eastern Region[HMF] Sunshine Coast Chapter.
1990 Mariner Blue Roadster
Verithin Guitars
Postby orx626 » Tue Jan 27, 2009 9:00 am
Big G wrote:Nice instal Danny!...Good job you had one to practice on 8)
Hi Geoff, the practice certainly helped :mrgreen: .
Yes there are plans for an air to water intercooler later this year as I need to get stuck into the NC. The intercooler installation will be done in conjunction with a coolant reroute kit that I'm working on. This will provide the necessary space between the radiator and the front of the engine for the heat exchanger.
Steampunk
Postby Steampunk » Tue Jan 27, 2009 12:32 pm
my eyes just turned green 8)
Postby 93_Clubman » Tue Jan 27, 2009 11:46 pm
yeah it looks like the nose pulley that's good for an extra psi, so with the upgraded belt tensioner it should be around 7psi - 67.5mm is standard & 62.5mm is the one for a bit of extra boost.
rhysk
Vehicle: NB8A - Supercharged
Postby rhysk » Thu Jan 29, 2009 10:41 pm
Looks like a BR Performance pulley which is 62.5mm. If your crank pulley is standard then you'll be right at the supercharger's max rpm at redline and should be making 7 psi.
Handy chart: http://www.trackdogracing.com/website/s ... _chart.htm
supercharged NB (in Brisbane) - qr 1:01:75 (s), 1:05.90 (c)
jaguar xjr supercharged v8
Big G
Postby Big G » Wed Feb 11, 2009 7:54 pm
A couple of questions for you guys. I've just measured the nose pulley on my JR and it's 78.76 mm diameter, with a standard bottom pulley, what boost should I be making, and what size pulley do I need to spin the S/C to max rpm?
Er, take no notice I 've just read the thread properly, see above post.....duh
Image :mrgreen:
Geoff
Verithin Guitars
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Fri Feb 27, 2009 9:14 pm
Nice air box. I'd love something like that myself.
Loving all these Supercharged 5s.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
pixola
Postby pixola » Tue Mar 24, 2009 1:15 am
I found some old pics.. seems appropriate to put them up here
Custom 1998 NB w/T28 BB, Autronic SM2 (Silverwater Auto Svcs)
Max about 0.85bar on stock engine makes 165kW@wheels (Performance MetalCraft)
Mazda Torsen diff 4.1 ratio (Thanks John Newells)
Tein Flex Coilovers / Clutch Upgrade (Thanks Les)
AP 4 Piston Brakes / 285x25mm rotors (Racebrakes)
Momo Rookie Seat ( getting a bit worn now ) (The mad Yacht Doctor)
Been running like clockwork for 8 years, and only has had oil and spark plugs since build.
Just got a yellow sticker for the first time this month.. No probs though :) It's all good with the DPI.
Mazda didn't build the MX-5 to chirp on gearshifts
Sean
Postby Sean » Tue Mar 24, 2009 1:31 am
Long time no see with the old pixola mobile. I have always loved that car, it along with the original gurglr were the two MX5s I always wanted mine to be like back in the day.
Postby Jeo » Sat Apr 18, 2009 12:43 pm
nathantp85, more photos and information on the car in general please :) (probably in a different thread though...)
wazman
Postby wazman » Thu Jan 14, 2010 4:59 am
I've got a build thread in "garage chat" if you want in depth.
T25g on stainless steam pipe manifold
3inch exhaust
pwr cooler
160 rwkw @ 10psi
ilovedrift.com
Rob E
Postby Rob E » Tue Feb 16, 2010 1:32 pm
Took a couple of shots over the weekend :
Its Dmags old Clubman, a real beauty.
Engine:
1.8 with full AVO kit
GT28 Ball bearing turbo
AVO Manifold
AVO Dump
AVO intercooler
Custom made 2.5" exhaust / Stock Cat 2.5in Flanged
Turbosmart Boost controller
Turbosmart BOV
RR Fuel pressure Regulator
Walbro fuel pump
360 cc GTX injectors
Air intake temp sensor
Link G4 Storm ECU
50mm Cooling pro Radiator
Power circa 150rwkw at 10psi
I have picked up some 550cc injectors and will be putting in a Metalcat and getting it retuned soon to run 12psi. I know the next restriction is the AVO downpipe, but im going to leave it in place. gotta stop some where.......
I am really keen to get some thoughts with regards to the Air Intake, up to a genuine 180rwkw DD Shootout mode level is it worth messing around with Cold Air feed given the NA's limited space and that the car is a turbo.....and that air is going to be superheated pre combustion anyway...and is there a noticeable difference on spool / response on a longer intake tract?
Postby 93_Clubman » Tue Feb 16, 2010 2:57 pm
Looking good Rob - not sure if you saw this 3 page thread from just over a year ago: CAI and Forced Induction ... waste of time? viewtopic.php?f=81&t=33931
Rob E
Postby Rob E » Tue Feb 16, 2010 3:05 pm
93_Clubman wrote:Looking good Rob - not sure if you saw this 3 page thread from just over a year ago: CAI and Forced Induction ... waste of time? viewtopic.php?f=81&t=33931
Thanks for that link, you are a champ. I'll check it out. Im checking out miataturbo on this issue too.
