MX5 mania turbo build
speed
Re: MX5 mania turbo build
Postby speed » Thu Jun 01, 2017 9:29 am
What diff will you be using?
anastasic81
Re: RE: Re: MX5 mania turbo build
Postby anastasic81 » Thu Jun 01, 2017 9:21 pm
speed wrote:What diff will you be using?
3.9 torsen
Sent from my Pixel XL using Tapatalk
speed
Re: RE: Re: RE: Re: MX5 mania turbo build
Postby speed » Thu Jun 01, 2017 11:41 pm
3.9 torsen
Perfect! So when will the first track day be? I'd be keen to come watch :)
anastasic81
Re: RE: Re: RE: Re: RE: Re: MX5 mania turbo build
Postby anastasic81 » Fri Jun 02, 2017 12:33 pm
3.9 torsen
At this stage not decided. I want to drive around the streets to ensure all is ok. I'll let you know
anastasic81
Postby anastasic81 » Fri Jun 09, 2017 5:25 pm
Running into issues
Car has a misfire. It happens when the Boost is turned up.
Tried changing the coil pack which works for 1 run but after that it misfire again!!!! Then swap back and the same thing!!!
Anyone had a similar problem?
speed
Postby speed » Fri Jun 09, 2017 6:43 pm
Magpie was getting a miss from the cas sensor. Fixed with a cable tie.
How much did you turn the boost up to? I can't comment on the stock coils as i swapped to toyota cops for my build and have had no issues.
anastasic81
Postby anastasic81 » Fri Jun 09, 2017 8:58 pm
speed wrote:Magpie was getting a miss from the cas sensor. Fixed with a cable tie.
Mania tried changing the CAS, didn't fix.
It ran at 6-7 on the first run then misfired on the second
adryargument
Vehicle: NB8A - Turbo
Postby adryargument » Fri Jun 09, 2017 9:43 pm
220hp is all you really want without *blowing* / *testing* the engine.
However 7k, wow, im sitting at 14psi on a td04 ($100) and am somewhere over 200hp. i suppose i built my own dp/manifold/exhaust/cops etc etc.
The welds sure dont look as pretty but at the end of the day they are glorified pipes.
davekmoore
Postby davekmoore » Fri Jun 09, 2017 10:41 pm
anastasic81 wrote:Running into issues
Talk to Brendon Beavis about his LS ignition conversion.
anastasic81
Postby anastasic81 » Fri Jun 09, 2017 11:33 pm
adryargument wrote:220hp is all you really want without *blowing* / *testing* the engine.
Not to be rude but I'm not here to compare pipes.
Would love to spend less but I don't have the skills nor equipment.
Post was to share my build and now we are running into a few challenges. I believe it's to do with the Megasquirt 3 diy.
Locutus
Postby Locutus » Sat Jun 10, 2017 12:46 am
anastasic81 wrote:Not to be rude but I'm not here to compare pipes.
You aren't the one being rude.
Tried new leads and plugs? What plugs? What gap?
What sort of challenges with the MS3? Who built it?
anastasic81
Postby anastasic81 » Sat Jun 10, 2017 1:34 am
MX5 mania put in new plugs and tried switching up coils, not sure if the leads were changed. They gapped the plugs but not sure to what.
The unusual thing is it does one power run then starts playing up. Let it rest for a while and it does it again.
Ecu was build buy a gentleman in Vic. Given the circumstances he has been helpful. He is sending out another ecu just to rule out. He said it may be the coil drivers on the ecu but i wanted to know if anyone else has something similar to ensure we have everything covered off
StanTheMan
Postby StanTheMan » Sat Jun 10, 2017 6:53 am
While there isn't a resolution for this one. And it may be a different issue. As well as yours being a ms3. I'd keep my eyes out on this thread.
https://www.miataturbo.net/mspnp-55/ms2pnp-no-start-keeps-toasting-ignitors-93350/
speed
Postby speed » Sat Jun 10, 2017 7:19 am
anastasic81 wrote:MX5 mania put in new plugs and tried switching up coils, not sure if the leads were changed. They gapped the plugs but not sure to what.
I'd say that mania would have everything covered.
Is great that another ecu is being sent.
Just spit balling here but since it happens when attempting to raise the boost, could be map sensor, boost control or injector drivers as mentioned.
Failing that possibly a wiring gremlin.
The new ecu should rule out all of the above except the wiring, unless it is a boost setting but again, suspect mania would be all over it.
Fingers crossed the problem is fixed with the ecu :)
anastasic81
Postby anastasic81 » Sat Jun 10, 2017 8:08 am
StanTheMan wrote:While there isn't a resolution for this one. And it may be a different issue. As well as yours being a ms3. I'd keep my eyes out on this thread.
Thanks, the only thing is it's not cooking the ignitor.
