got a car bracket for my phone today.
Most apps seem to work only on blue tooth. This one doesn't at this time. I happen to have the attachment required to connect it to a USB.
I currently connect to the laptop to the MS2 via RS232/USB cable. My samsung came with an attachment which connects to the USB connection from the Mega squirt 2 into my phone.
cool little app.
RPM & speed is the main gauge.
there are other 6 secondary gauges you can add choose from. Swap change. there must be 30? possibilities?
I currently have as the secondary gauges
AFR
AFR Target
MAP
CLT
MAT
Spark Advance
The app will give you the 6 max values for those gauges you choose to run. You also have an option to run 3.
you can reset your max values by a press of a button.
If you choose to log It will also give you the peak values for that particular log.
That about sums it up.
Its a great little guage app.
Thanks for letting me have a go Lockie.
Lokiel is also talking about adding gears & all that....even cooler for the MS2 users
the one thing I love....is that it automatically starts the app once I connect the phone ( although that's a setting I chose).....such an awesome thing for a fat fingered useless smart phone user like me. But my Google assistant doesnt know what app I'm talking about when trying to stat it by voice command. maybe call it something simpler?
