GT2554R
M1474
Vehicle: ND - Turbo
Re: GT2554R
Postby M1474 » Fri Oct 18, 2013 4:00 pm
I'm going to look at a low k t28bb but the guy called it a disco potato. How can I tell if its a 2850 or a 2560?
GHETTOCET
Re: GT2554R
Postby NitroDann » Fri Oct 18, 2013 4:16 pm
read the part number off the tag on teh centre housing and google it.
M1474
Vehicle: ND - Turbo
Re: GT2554R
Postby M1474 » Fri Oct 18, 2013 5:08 pm
It dosent have one
GHETTOCET
Re: GT2554R
Postby NitroDann » Fri Oct 18, 2013 5:30 pm
You have to take the housings off and measure. it looks exactly like every OEM Gt2560r I have ever seen, in the pictures.
Re: GT2554R
Postby Okibi » Fri Oct 18, 2013 7:21 pm
The disco potato was designed for a miata so it's pretty suitable.
Re: GT2554R
Postby Okibi » Fri Oct 18, 2013 7:22 pm
This is what they can do on a 1.6
zoomzoom
Re: GT2554R
Postby zoomzoom » Sat Oct 19, 2013 12:14 am
T25/T28 refers to the rear wheel then the next two numbers are the front wheel. CA18 S13 had a T2554 and the SR S13 had a T2560 both the same OD rear wheel but a larger front wheel. Later models eg. S15 had a GT2860, a GT ( ball bearing) 28 (T28 rear) and 60 (60mm front wheel).
To add to that the wheels have a "trim" which is defined as the inducer/exducer.
FYI a T2560 from and SR S13 is quite a nice fit on a 1.6 however as Dan mentioned above, one of the only situations you may be able to make use of the T2554 would be motorkhana. If you are looking at the tiny and super responsive then you could probably have a look at the GTR turbos too, there are quite a few different ones but most have a T25 rear and around a 56mm front wheel. As a rough guide I would expect to pay in the region of $300 or less for any of the above.
Tim
TTT
Re: GT2554R
Postby TTT » Sat Oct 19, 2013 12:56 pm
Gtr turbos are useless in single form. Don't waste your money.
If you want T2x based stick to SR20 turbos. Gtir turbo is biggest of that bunch..
If you want cheap T3 based turbos, then skyline gtst turbos are cheap and anything from the r32 gtst up has ball bearing turbos. But ceramic exhaust wheels.
Re: GT2554R
Postby NitroDann » Sat Oct 19, 2013 1:30 pm
Just stick with wrx and S chassis turbos for good cheap reliable power.
IMO.
M1474
Vehicle: ND - Turbo
Re: GT2554R
Postby M1474 » Sun Oct 20, 2013 2:47 am
I went and checked out this T28BB.
It did have a plate on the Chra tha was just so caked with dirt the guy hadn't seen it. It was a GT2560R when I ran the part number but the guy claimed it had only done 8000km and I just don't believe him.
In the last three months I've only seen 2 2554s for sale and both were over $800 and still no idea what came with them as stock.
So price and availability would dictate I should just get a T25. But it seems that any advantage of the lower rpm spool of the small turbo would be negated by the reduced lag of the BB 2560.
I guess what I'm asking is:
If I can't find a 2554 as my instant boosting turbo, is there any reason to look at the T25 or is the 2570 just as responsive down low with more up top to boot?
Or have I been sucked in by the BB hype?
I don't know, Im tired of sifting through endless Nissan forum posts and just want to go to bed.
GHETTOCET
thehillsarecalling
Re: GT2554R
Postby thehillsarecalling » Tue Oct 22, 2013 6:01 pm
What he said. I also have a 1.6 turbo project, also with standalone MS2 and also confused as to the best turbo for my requirements.
Do the 4 bolt / 6 bolt turbos share similar interfaces (flanges, oil piping etc) enabling easy switchover between turbos? Or will it require building new exhaust manifolds each time a t25 / 28 is switched over ?
Daily: '91 Malibu - NB8B conversion, 6sp, Teins, Whitelines
Terribly Missed: '02 Black SP (#55)
Plus about 12 others over the years..
M1474
Vehicle: ND - Turbo
Re: GT2554R
Postby M1474 » Tue Oct 22, 2013 6:19 pm
I meant 2560 two posts up.
Ray, I think the flanges are the same.
Tim, are you sure the s15 came with 2860? I thought that was a myth.
GHETTOCET
TTT
Re: GT2554R
Postby TTT » Tue Oct 22, 2013 9:12 pm
it is a myth.
I posted the part numbers on the previous page which have been confirmed by Nissan directly.
"SOME" got ball bearing turbos.
majority didn't.
zoomzoom
Re: GT2554R
Postby zoomzoom » Tue Oct 22, 2013 9:23 pm
It's a while since I have played with these turbos but I just had a quick search and it looks like the s15 is a 25 rear, it is listed at 53.0mm where a t28 would be 53.9mm. If you find any turbos just try to do a google search for specs/dimensions based on the part number, all the garrets I have seen have a small alloy plate on the CHRA with the numbers on.
I used to run an s13 turbo on my 1.6 and that was pretty quick to spool up especially when using launch control, that worked quite well for motorkhana. The great thing about the s13 is that they go for around $200 pretty well any day of the week for a good one, so even through they are journal bearing the price and availability in case of a failure pretty well makes up for the slight difference in spool.
I am now running a GT2871R on a 1.8 and that spools pretty quick too but nothing like the S13 turbo did. Before the S13 turbo on the 1.6 I had a GT2556 from a R34 GTR, now that was quick but the flow or lack thereof limited the top end considerably.
Tim
elitee
Re: GT2554R
Postby elitee » Wed Oct 23, 2013 12:28 pm
Got one for sale if your interested.
viewtopic.php?f=44&t=60526&p=760294#p760294
