How to turbo your NA for $2000.
Re: How to turbo your NA for $2000.
Postby NitroDann » Sun Jul 07, 2013 11:33 pm
emily_mx5 wrote:So if someone wanted to do this, a list of everything required would be:
ex Manifold yep
ex manifold gasket Nope reuse
turbo yep
turbo gasket to the dump
dump yep
dump to stock cat gasket reuse
oil feel lines yep
coolant feed lines no
pod filter yep
several sillicone joiners and hose clamps yep
metal cross over pipe (or would the stock plastic one suffice?) Im going to make a new one it will be easier.
ecu (such as a MSPNP2) + map sensor? ms comes with sensor, you want the ait sensor though.
boost gauge? On the laptop when you tune MS
anything else?
Nuts and bolts to bolt the manifold to the turbo and then to the downpipe, some rtv, but thats it, maybe a bit if vacuum line and a litte T piece for it..
bootz
Postby bootz » Mon Jul 08, 2013 12:38 am
ex Manifold
ex manifold gasket
turbo
turbo gasket
dump
oil feel lines
coolant feed lines
pod filter
boost gauge?
anything else?
Go on do it, you know you want to. I wish I was close to Newcastle. :mrgreen:
M1474
Vehicle: ND - Turbo
Postby M1474 » Mon Jul 08, 2013 12:38 am
*leaves thread inspired.
GHETTOCET
emily_mx5
Postby emily_mx5 » Mon Jul 08, 2013 12:56 am
ha, stage 1 really isn't as big or scary or expensive as everyone makes out huh.
dat dose :twisted:
M1474
Vehicle: ND - Turbo
Postby M1474 » Mon Jul 08, 2013 1:13 am
What size are your 90's and T's Dann?
GHETTOCET
bootz
Postby bootz » Mon Jul 08, 2013 1:16 am
emily_mx5 wrote:ha, stage 1 really isn't as big or scary or expensive as everyone makes out huh.
dat dose :twisted:
Hit it girl, you on. 8)
Postby NitroDann » Mon Jul 08, 2013 1:25 am
M1474 wrote:What size are your 90's and T's Dann?
1.25 or 1.5 depending on the application, on an mx5.
M1474
Vehicle: ND - Turbo
Postby M1474 » Mon Jul 08, 2013 2:03 am
Say the application is an NA6 log manifold.
GHETTOCET
Sean
Postby Sean » Mon Jul 08, 2013 2:05 am
dat dose :twisted:
Horses for courses, I'm sure Dann will put something together efficiently that will likely outperform the Greddy, but what you get for $2k is not going to compare to what others are quoting $5k (or more) for.
Generally the higher quotes account for the related upgrades that it seems this car already has like exhaust, clutch etc. as well as the big hidden cost of engineering.
As I said in the beginning though, I'd rather like to see what he comes up with before we all go judging it.
Old Dude
Postby Old Dude » Mon Jul 08, 2013 9:02 am
Watching with interest Dann, it sounds to good to be true, but I hope you can do it :D
You'll have customers lining up at your door
Dale 8)
MX 5 2001 Grace Green
NB8B
emily_mx5
Postby emily_mx5 » Mon Jul 08, 2013 10:31 am
dat dose :twisted:
Absolutely agree, i would never go this route. Don't doubt Dann's capability, and I'm sure alot of people would find this great, but I will be doing my turbo set up with all the things, plus engineering which im sure will be extortion.
Plus whats the point of a turbo car if you don't have a f*ck off front mount or a bov that goes pppssshhh :D :roll:
Postby NitroDann » Mon Jul 08, 2013 11:25 am
M1474 wrote:Say the application is an NA6 log manifold.
In this case 1.25, if the goal was going for 300whp+ 1.5".
Sean wrote:Generally the higher quotes account for the related upgrades that it seems this car already has like exhaust, clutch etc. as well as the big hidden cost of engineering.
This car has a 2" exhaust, that is all.
emily_mx5 wrote:Absolutely agree, i would never go this route. Don't doubt Dann's capability, and I'm sure alot of people would find this great, but I will be doing my turbo set up with all the things, plus engineering which im sure will be extortion.
Many factory turbo cars do not come with BOVs, the CA18DETs didnt, RB30ETs didnt, the monster homologation FJ20 never had one and the car from which this turbo comes from, the ET pulsar, never had one.
For interest sakes for those playing at home, a full SS piping setup with a 300whp capable front mount with everything you need, is 500 dollars for an MX5, if you supply a BOV (Im only going to order it online like you so you might as well cut out the middle man) ill fit it in any configuration for no extra cost. So add that to it.
But that Isnt the point, you can add 100 things to the 'do it right list' that simply aren't needed for a reliable bump in power of 40-50%. You could add that it needs a BOV, the car with this turbo from factory never had one. (ET pulsar)
You could say it needs an intercooler, again, nissan didnt think so for the ET pulsar.
You could say it has to have an exhaust bigger than stock, again Nissan Disagreed.
And the stock na6 clutch if in good nick will cope just fine.
Anyways, everyone hold their horses Ill put more photos up as the day goes on.
Muzdaman
Postby Muzdaman » Mon Jul 08, 2013 11:52 am
I love where this is going.
narita
Postby narita » Mon Jul 08, 2013 12:45 pm
how much would this turbo system running on 6-8 psi really affect the life of the engine?
also is there any associated headaches with VVT + turbo.
cheers dan!
WINTON PB - 1:57.4000
TTT
Postby TTT » Mon Jul 08, 2013 1:15 pm
Just some other thoughts for people wanting to do it cheap.
RB20 turbos are ball bearing and can be had in good condition for under $100.
Stock skyline bovs (recirc) are about $30 at most.
Standard R32 or R33 GTST skyline intercoolers (good for about 160rwkw while on skylines) are usually thrown away (R34 ones cost about $100 as they are a chunk thicker and good for about 220rwkw)
A subaru Liberty RS (or Legacy RS) turbo standard water to air intercooler system are usually sold for about $50 - usually good for about 160awkw on the subbies.
Look forward to updates on this thread.
Users browsing this forum: No registered users and 117 guests
