Questions. 1.8 head gasket. pistons.
- alexpav
- Vehicle: NA8 - Turbo
Re: Questions. 1.8 head gasket. pistons.
I felt like burning my car when it stopped moving! haha
Worst part is, I dont want to work on it! oh well.
Will be well worth the headf**k haha
Thnx for the advice!
WILDCARD BITCHESSSS
- alexpav
Any advantages in using adjustable cam gears?
WILDCARD BITCHESSSS
- NitroDann
Not a whole lot with stock cams, will allow you to tune the torque curve to be broader or peakier and move it up and down the RPM a bit if you dont like the turbos delivery.
- alexpav
I bought the pure performance rods and i am going to change the pistons, for what its worth i may as well...
Anyone used DURATEC pistons? or NPR Pistons?
Any recommendations?
Anyone have any unused pistons for sale?
Alex
Alex
WILDCARD BITCHESSSS
- alexpav
- Sean
US eBay is probably the cheapest place for decent pistons.
- alexpav
is that the NPR ones? They are only 160 delivered!
And apparently made in Japan, From what I have read they make a fair bit of OEM stuff for new car...cant be too bad...can they?
What compression ratios should i be looking at for a turbo setup?
WILDCARD BITCHESSSS
- Sean
alexpav wrote:is that the NPR ones? They are only 160 delivered!
There are lots of worthy ones - I've never used or even held NPR ones...
I've used CP which were an excellent piece of gear, but are a bit more than NPR. Heaps of guys have used hypertech etc, if you're looking 200ish rwkw, any of them will be fine including NPR I guess.
In terms of comp ration, it depends on your plans. You could go lower comp if you want massive boost in the futre, but if you're sticking with the S15 T28 turbo, stock comp will be ideal, it'll also leave you without a hole off boost, not that it takes long for the little turbo to overcome the boost threshold/lag point...
At the sort of boost you'll be running with that turbo, rods and more specifically rod bolts will be your biggest issue - Also, get your block checked before you go buying a piston set, just to make sure you don't want/need to go a little over sized.
- alexpav
I think il b using the T25 will come on quicker from my experience with 200s/180s.....
Whats considered low/high comp?
I have bought pure perfomance rods with arp studs...
WILDCARD BITCHESSSS
- Sean
alexpav wrote:I think il b using the T25 will come on quicker from my experience with 200s/180s.....
Go the T28 - trust me, they are fine on a 1.6 and the s15 turbo is almost identical to what is used on the factory turbo 1.8 SP model. It's more than quick to spool on a 1.8 mx5.
Low/high depends on the person. from memory different MX5 engines ranged from 9 to 9.5 to 10:1 compression ratios, in my opinion 9.5 is pretty nice for 15-16 psi on the t28 (assuming no major head or cam changes).
- alexpav
no head work or cams (yet)
hmmm got me thinking now...
Really i was only selling the t28 to get the cash! haha...
WILDCARD BITCHESSSS
- alexpav
Helllo again!
ok im running the T25
I got the rods/arp studs.
Its an NA8.
Im not sure what compression ratios i should be looking at.....
Which pistons should i run? Any suggestions??
There are so many on the market at so many different prices?
Your experience/suggestions would be appreciated.
Thanks again
Alex
Its an NA8.
Thanks again
Alex
WILDCARD BITCHESSSS
- NitroDann
Stock to 270-280rwhp.
Above that supertechs.
- timk
I'm rocking CP pistons just because a mate has them in his mental big turbo SE and it holds up. They are probably much of a muchness though.
- alexpav
ok and how do i know what compression ratios to look at?
WILDCARD BITCHESSSS
Users browsing this forum: Google [Bot] and 7 guests
