Diagnosis
Novice1
Re: Diagnosis
Postby Novice1 » Fri May 25, 2012 6:29 pm
Problem solved. Plug with smaller gap did the trick.
thsnks tim
Steampunk
Re: Diagnosis
Postby Steampunk » Sat May 26, 2012 12:10 am
You need quality colder plugs.
Didn't anyone from any of the recent tuning shops replace them? Or at least suggest it? I assumed they did as it's a basic upgrade that corresponds with higher boost mods.
timk
Re: Diagnosis
Postby timk » Sat May 26, 2012 11:54 am
'zoomzoom' and I have been using BCPR7ES copper spark plugs successfully for boosted applications. They come gapped at 0.8mm which should be good.
Re: Diagnosis
Postby bruce » Sat May 26, 2012 12:31 pm
I'd also change the spark plug leads...
Re: Diagnosis
Postby 93_Clubman » Sun May 27, 2012 4:46 pm
:mrgreen:
4sfed5
Re: Diagnosis
Postby 4sfed5 » Sat Jun 02, 2012 7:57 pm
saboteur wrote:'zoomzoom' and I have been using BCPR7ES copper spark plugs successfully for boosted applications. They come gapped at 0.8mm which should be good.
im pretty sure thats what i run in my car too. no messing around with gapping plugs. just buy and chuck them in.
Also i am surprised that people dont do something to address the Volt drop to the coils from the stock wiring loom. the voltage getting to the coils is pathetic.
i am going to run a heavy wire from my alternator via a relay mounted next to the ignitor. that way the coils will get all the voltage they deserve.
A.Chen89
Re: Diagnosis
Postby A.Chen89 » Sun Jun 03, 2012 7:46 pm
not living up to their full potential eh?
PaulF
Re: Diagnosis
Postby PaulF » Mon Jun 04, 2012 6:54 am
A.Chen89 wrote:not living up to their full potential eh?
Ohm my goodness, that was terrible. :P
rxmx
Re: Diagnosis
Postby rxmx » Fri Jun 08, 2012 7:23 pm
Hey Ron,
Just wanted to ask, what plugs did you end up going with and what gap was the car happy at?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
