critique this setup
- Dweezle
Re: critique this setup
You can bend gently the condensor up an inch or 2.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- zossy1
critique this setup
My critique? This setup looks and feels half-assed. That it not meant as a flame (though it sounds like one). You are clearly trying to do this inexpensively and that's ok, but saving $100 here and $200 there is going to severely compromise the final product. My guess is you will pull the kit off and sell it in 6-12 months time once you get sick of all the trouble it is going to cause you.
Oh, and just pull off your a/c and p/s. You can do without it ;)
lol thanks for the feedback. I would like to go full ecu like the megasquirt but i dont want to do too many changes to the car that cant be reversed if i get defected. Defects in SA are a huge hassle and the car has to be put back to factory specs. This project isnt about pushing maximum power its just about minimal gains for a moderate outlay. If i wanted power i would have kept my FD. Ill post pics when im done, maybe you'll be surprised.
- NitroDann
I think you have entirely missed the point zossy is making.
You saved 150 over proper engine management.
You say you dont want the hastle of MS because you have to revert to stock, so you have chosen a half assed wire in job, rather than a good, much safer, plug and play 5 minutes to uninstall ecu.
Its will drive crap, have a boosted powerband of 1500-2000rpm, and be unreliable.
- Vehicle: NA6 - Turbo
its like that visa ad...
money saved on injectors.....$100
money saved on fuelling.....$200
money saved on timing.....$200
money spent on your blown up engine because you were too cheap to do it properly..... a LOT more than anything saved.
critique this setup
The emanage I have comes with a na6 specific harness that incorporates the timing and injector harness and it's from greddy not some hack job it is literally pnp. It will not be as good as a mega squirt but it's going on a basic setup which I will have no intentions of upgrading except maybe from the td04-9b turbo to the td04-15 if it ever needs a rebuild. Money is not the issue I just do not want to go extreme with the car SA laws are much stricter than other states.
- NitroDann
A turbo and an ecu is a turbo and an ecu as far as the law sees it.
A blown up engine only costs 200 so it isnt that bad.
but you need to see the difference between how a hack job and a nice setup drives.
You dont just get more power, the greddy setup isnt really fun, its faster, but so is a VT commodore.
finally finished the install. got everything in but the FPR and emanage, ill start on those tomorrow. took it for a very tame drive to iron out any leaks etc and everything seems fine. lowest reading i got from the wideband was 12.5 with it idling around 15. My clutch was bad before and is totally useless now. is it normal for the wideband to go super rich (off the scale) when i take my foot off the accelerator?
- NitroDann
It will go rich then hit quite lean normally.
here are some pics. Needs a really good cleanup and some small stuff done. emanage map sensor arrived today so ill get to work on that soon. tonight new clutch gets put in. Had another drive and it was great, dont know the true potential as ive been shifting at 3000rpm.
- jerrah
Wow, might just be that I'm reading thread on my phone but that turbo looks tiny. I would be interested to see how it plots on a dyno.
1991 MX5
The emanage can log all those so I'll post up some graphs later.
- NitroDann
It cannot plot a dyno run.
Woops I meant boost curves. obviously not power
So Vrmmmpshhh did you remove your A/C to get that cooler pipe down there?
NB SE, NA 1.8.
