SE.. how would you get some blow off flutter.
- Aussie Stig
- Stig
Re: SE.. how would you get some blow off flutter.
When I was in Sydney I think it was "the wall" where you could get this.
- Boyracer
- MX-5 Encyclopedia
I used the Turbsmart Kompact, plum back with atmo, it's a direct swap and works well not too loud.
If you want turbo flutter, remove the BOV altogether and plug the holes which remain. If you want it even louder, get an aftermarket ecu which doesn't use an air flow meter (so you lose the afm) and put a pod filter on the mouth of the turbo.
As an experiment to see if you like, just remove the vacuum line to the BOV and fold the end back on itself to prevent it leaking air, and go for a drive!
