Oil Oil Oil everywhere...
Dweezle
Re: Oil Oil Oil everywhere...
Postby Dweezle » Fri Mar 23, 2012 4:18 pm
Mate... Your a champion.
Thanks for The help.
I have a compression tester coming home with me tonight.
Hopefully that Will help clear things up.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Dweezle
Postby Dweezle » Tue Mar 27, 2012 9:17 am
I picked up a brand new PCV valve for a GTX 323.
It is non Genuine, was from Repco.
But when i got home and took it out of the packet it and blow through it, it still slightly leaks.
If i shake it and try again sometimes it seals sometimes it does not.
So i assume at 8 or more PSI it prob stands no chance.
I have found a few guys in the states who are running a one way check valve before the PCV.
http://www.ebay.com.au/itm/2-HHO-Generator-3-8-In-Line-Check-Valves-WATER4GAS-/250523821570?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a54622602#ht_1187wt_1163
They are really cheap but i can not for the life of me find where i could get one in Sydney?
If anyone has an idea i would love to know.
I think this would rule that issue out, then i can sort out the Hot side vent into a catch can and go from there.
Oh and if you want a good read on Crankcase Venting on NA & TURBO, i found this really useful.
http://www.sr20-forum.com/information-library/34413-crank-case-ventilation-fully-explained-naturally-aspirated-edition.html#post446849
http://www.sr20-forum.com/information-library/44727-crank-case-ventilation-fully-explained-turbocharged-edition.html
Jeremy Clarkson
bear2230
Postby bear2230 » Tue Mar 27, 2012 9:36 am
Mark, Try Industrial Hose at Rockdale. Next to Bunnings. Talk to Dougie 9597-6315
He is one of the good guys.
Or Industrial fittings Sales 9605-3311
Richard
charlie_91
Postby charlie_91 » Tue Mar 27, 2012 7:36 pm
this is what happened with my car.. turned out the rings shat itself and forced me to rebuild the motor :beer:
Dweezle
Postby Dweezle » Tue Mar 27, 2012 8:39 pm
Ohhh really??
I wondered why you went a full rebuild.
If that is my issue i will just rebuild it in a few months.
Hoping i can get away with some improved ventilation for now.
Jeremy Clarkson
charlie_91
Postby charlie_91 » Tue Mar 27, 2012 9:41 pm
yeah we took the head off and did a leak down test and it failed. Just build it stronger ;)
Postby bruce » Wed Mar 28, 2012 2:03 pm
Now that sucks bigtime.
CHRISTolo
Postby CHRISTolo » Mon Sep 24, 2012 4:51 pm
Dweezle wrote:I picked up a brand new PCV valve for a GTX 323.
Hey mate did you ever manage to get the small inline check valve?
Dweezle
Postby Dweezle » Mon Sep 24, 2012 5:18 pm
Nah. I ended up figuring out my issue was just a blocked hotside vent from the cam cover.
Braineack reccomends the check valve though.
Prob worth getting.
Jeremy Clarkson
