Hi buz 138,buz 138 wrote:yeah iv'e heard they are quite a good manifold. thanks for some real world figures to go with it!
atm it has 140rwhp at 7psi ...so im looking for 200+
the reason for external gate is better/accurate control, if im doing a custom mani i might as well put one in and the most obvious....an mx5 with a screamer pipe
so the main reason now is room for a decent size dump....any pics?
cheers
As I mentioned before, all the B6 AVO kits I have done get aorund 230-240rwhp with an upgraded fuel system, (2.5" and above) exhaust and an aftermarker ECU system. If your goal is 200rwhp then why are you not just tuning the car for 15 psi (or whatever boost will get you 200rwhp)? If the boost curve is not great then there are cheaper options like changing your actuator, boost solenoid valve, getting an electronic boost controller or a good stand alone ECU.
Put simply, I really do not see the point of changing the manifold and adding a wastegate to your set up. I suppose I am coming from the perspective of "if it is not broken, why change/fix it"...? Especially in your case, where if you added some forged connecting rods to your bottom end, upgraded fuel system, a good ECU and dynotune, I can see you hitting (a lot more than) your target without touching the current turbo kit hardware.
Of course, if you are wanting to do this for pure fun (noise) factor, bragging rights or just because you can then just ignore my spew above.
Oh and if that is the case, I have a slightly used (less than 9,000km) GReddy Exhaust Manifold with the tuned length runners and external wastegate flange for sale. Terry from our club has just over 170rwkw/232 rwhp on his MX5 with only B6T (Familia) factory pistons. PM me if you are interested.
Les @ MX5 Shop
