Post your turbo / supercharged setup
Blue94t
Postby Blue94t » Thu Nov 27, 2008 7:59 pm
mx52nv,
New setup is the bastard with a Nissan heart.
S13 SR20det with Nissan gearbox and Rx7 SIV diff.
Motor is stock bar the dry sump until it is engineered but I have forgies, rods, turbo and a few other bits to go on once it is engineered, registered and the suspension sorted.
Jake
4sfed5
Postby 4sfed5 » Thu Nov 27, 2008 8:07 pm
1990 1600 MX5
stock block and head.
Subaru VF10 turbo on custom weld el manifold and 2.5" exhaust
"330cc" Black top injectors (actually flow more like 375cc)
Greddy emanage blue/o2 clamp
RX7 AFM and custom cold air box
Custom I/C piping and an Isuzu Intercooler
stock Subaru Bosch BOV
DIY dual feed rail
GFB maual boost bleed.
Heated O2 sensor
Dyno'd at 142 RWKW (has made more but now has less due to a diff on its last legs.) :wink:
http://www.cardomain.com/ride/264041/6
Sean
Postby Sean » Thu Nov 27, 2008 11:25 pm
4sfed5 - That's excellent results from a different to the norm - well thought out system. Nice cardomain page!
Fuzzlet
Postby Fuzzlet » Thu Nov 27, 2008 11:38 pm
12.9 on street tyres...not too shabby. My old NA could only muster a 13 flat. I tried quicker, but would only end up blowing diffs.....it had:
Wiseco pistons
Carillo H beam rods
Balanced Crank
Ported head
Up-spec valve springs (cant actually remember what it used)
Bosch 440cc injectors
Genuine SP manifold, turbo and dump-pipe
2.5" Custom exhaust
Mania CAI (Yes, we did it with turbo)
Wolf 3D ECU
Put out around 180rwkw. Will post pics and details of new car when I have time haha
bjones
Postby bjones » Fri Nov 28, 2008 2:03 am
It has seen over 250 rwkw::::and has been tuned more
12.1 on street tyres...open Diff.Terminal speed of 127mph YES 127MPH:
Engine fully balanced
Wiseco pistons
Carillo H beam rods
Balanced Crank
ARP, rod, head ,main cap, crank bolts
Ported , polished and CC'd head
Big Arse injectors
Carbon forced , TRUE cold air intake
Exhaust
Remote oil filter
remote oil cooler
SMB Computer
Daniel's Magic and a few other secrets
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
rxmx
Postby rxmx » Sat Nov 29, 2008 8:48 pm
mx52nv wrote:
Blue94t wrote:Ran a 12.9 1/4 on crappy street tyres
New setup should make more power and heaps more torque.
WOAH!!! 12.9 second quarter mile on street tyres :shock:
Very nice :mrgreen:
What is the new set up may I ask? :)
I did that time slip when I used to own it. that was before I got the new dump pioe made up and before I got some street slicks for it. Was running worn 195's and managed a best 60ft of 2.1 on that run due to wheelspin. Man I miss that car.
Jake, How long till its on the road with the new setup?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
mhj
Vehicle: NB8A - Supercharged
Postby mhj » Sun Nov 30, 2008 1:41 pm
there no point in posting a pic 'cause it aint that different or interesting( and i dont know how :oops: )
but
bought the 99NB ( bright red as factory standard performance addition :lol: )at 16k on the clock...put about 10 k on it over the 6 mths ive had it...a daily driver , not a trackstar.
it has had a jrsc45 since day 1. lowered with standard shocks. simmons 16inch wheels( noiice!). factory everthing inc body kit and bliggy interiorwith timber and chrome. hard top.
all fully engineered
ive added
adaptronic ecu.
380 cc injectors
full 2.25 stainless exhaust inc xforce heat wrapped headers and high flow cat.
front and rear signature sways
fm butterfly brace( a very good thing!)
torque box twin hoop roll bar.
mania tuned to an alleged 132 rwkw with 380( or perhaps i misheard...280) nm
interested to add
front and rear shock tower braces...front is a little complicated due to room
more psi...it only does 5 psi ....( too much is never enough)
more underhood cooling....intercool or hopefully just upgrade radiater
better than the currently standard brake pads
maybe new seats( why not!)
and maybe a sub woofer for the ubiquitous heavy reggae bass.
suggestions re adds/ suggested adds are invited...but i will probably ask specific ? in a new post
ENJOY
mhj
mhj
CT
Postby CT » Thu Dec 04, 2008 7:18 am
2004 SE converted to SP Spec
Carillo A beams
Wiseco 9:1 pistons
Everything else stock and unmodified in the donk
Head is stock
Cams are stock
Haltech E8 ECU, boost controller and wideband
Standard, unmodified GT2560 turbo on stock manifold, stock dump pipe
3inch stainless exhaust
580cc injectors, modified returning rail,
Sard rising rate FPR
Bosch VL turbo fuel pump and alloy surge tank
PWR 550x210mm intercooler, 2in piping
188rwkw shootout mode, 12psi boost
Brett_MX5
Postby Brett_MX5 » Sun Dec 07, 2008 9:04 pm
I'm pretty sure I'm the only person silly enough to do this conversion :D
1999 NB8A - SE Engine & Drivetrain
Installed by MX5Mania
Upgradged from original SE
Intercooler
Intake
BOV
NB8A Plenum (short & long run)
Custom Exhaust
ECU
SP Radiator
Currently @ 150rwkw
"You tried your best and failed miserably,
The lesson is, never try"
-Homer Simpson
Sean
Postby Sean » Sun Dec 07, 2008 9:18 pm
Brett, I've always wanted to retrofit an SE engine, box, diff into an NA.
Fatty
Postby Fatty » Sun Dec 07, 2008 9:32 pm
very very old AVO stage 1 kit, mated to an mx5 factory CAI.
not using the electronics from the avo kit , instead running 460cc rx7 injectors and a jaycar DFA.
custom made mandrel bend 2.5inch exhaust by unique exhausts.
cooling pro radiator.
running a very mild, low boost tune atm, only 118rwkw but still heaps of fun to drive.
probably will be updating parts of this set up soon, stay tuned.
OVERDRAWN
Postby OVERDRAWN » Sun Jan 25, 2009 12:42 am
Where are all the Superchargers
OD
Postby 93_Clubman » Sun Jan 25, 2009 1:44 pm
there aren't as many Forumites with superchargers as there are turbos, but here's an SC install that's happening this weekend:
viewtopic.php?f=57&t=29490&start=75
Big G
Postby Big G » Sun Jan 25, 2009 3:42 pm
Here's my S/C instal on a '90 Import. The system used to be fitted to Sabatours car
Dyno'd a while ago, rear wheel figures
I've heard comments that these JR kits are only for old blokes who want to save changing gear on the motorway, I'll take any of these doubters for a ride and let them see for themselves. The HP figs are not corrected for sea level, so could be about another 10 RWHP
Geoff
Growing old disgracefully in Queensland
Founder of Eastern Region[HMF] Sunshine Coast Chapter.
1990 Mariner Blue Roadster
Verithin Guitars
d-mag
Road Track Rally
Vehicle: ND - Turbo
Postby d-mag » Sun Jan 25, 2009 7:02 pm
Needs more intercooler. :D Plenty of room for a cooler with a hot side.
I really like the colour matched valve cover. Looks great in blue.
MX5 Wanted. SE or NC (forced induction preferred :twisted: )
Users browsing this forum: No registered users and 84 guests
