Post your turbo / supercharged setup
bootz
Re: Post your turbo / supercharged setup
Postby bootz » Sat Jun 15, 2013 6:03 pm
NitroDann wrote:A bit of boost control bounce but yes it's very clean.
What shows that, the wiggles at the start of the torque plateau?
All I know about dyno sheets is that this one has a nice fat kw figure for an NB turbo. It is also has a nice flat power curve and a flat torque curve. I would like to see the Air/Fuel ratio readout as well.
Postby NitroDann » Sat Jun 15, 2013 6:49 pm
The bottom graph is a boost pressure graph.
bootz
Postby bootz » Mon Jun 17, 2013 8:25 pm
NitroDann wrote:The bottom graph is a boost pressure graph.
Yep, I know bugger all about dyno charts and about the same for turbos.
Postby Okibi » Tue Jun 18, 2013 1:38 am
Here's one of Simon's SE.
Rorge
Postby Rorge » Sat Jun 22, 2013 12:06 am
I made a new dump for my NA6-T28 setup which came out ok, did some hillclimbs with worn out RSR's..
https://www.facebook.com/video/embed?vi ... 8517852587
Then broke a couple of gears in one of many 5 speeds, fitted a 6speed and finally got a fresh tune from a mate in Sydney who's pretty good with Haltechs..(running an E8) It's running a 4.11 torsen so it's very short with the 6speed! 3500rpm @ 100km/h in 6th.
Engine bay with old 2.5" dump..
Dump
2 hours later with a hammer and using my Triton Superjaws as a vice and dolly I got this result..
Tune was on pump fuel and 550cc RX7 Injectors. (i'll switch to ID1000's when Ethanol is more readily on the pump. For now the car drives very smooth but lumpy idle 1000-1100rpm as the injectors don't appear to be able to pulse close enough together. It drives GREAT other than the wheelspin in 3rd if i'm a little hamfisted...
Postby NitroDann » Sat Jun 22, 2013 12:17 am
Awesome job, looks like a downpipe or 2 I made before :P
Its hard work to cold work that flange shape isnt it !
Rorge
Postby Rorge » Sat Jun 22, 2013 1:20 am
It was tricky but kinda like meditation! I love making stuff! (i'm just really crap at it) That's why I built this home-made $hitbox! :)
The exhaust manifold looks alot 'tidier' than that after I chopped off the whole base of the merge/flange and used some new thick wall pipe to make it stronger/cleaner.
PaulF
Postby PaulF » Sat Jun 22, 2013 4:38 am
Facebook video link doesn't work for me; do you have it set to public?
lazy330
Postby lazy330 » Tue Sep 10, 2013 10:47 pm
Can't take any credit for it as I bought it this way, but here's mine. Completely impractical, but heaps of fun.
Postby NitroDann » Tue Sep 10, 2013 10:56 pm
Looks like one of Suli's pieces of automotive art ? :)
lazy330
Postby lazy330 » Tue Sep 10, 2013 11:08 pm
No. Was actually built in Rockhampton.
Joe
Postby NitroDann » Tue Sep 10, 2013 11:09 pm
Awesome either way, thats a HUGE turbo especially on a 1,6.
What power does it make, on what boost?
Its a 3071 or similar?
lazy330
Postby lazy330 » Tue Sep 10, 2013 11:48 pm
Dann,
PM Sent.
Joe
Postby Okibi » Wed Sep 11, 2013 1:42 am
Love that intake manifold.
elitee
Postby elitee » Wed Oct 09, 2013 9:56 am
new setup, still need to tidy it up a bit more and get a tune
