Wanting quicker acceleration NC with cosworth Supercharger
Novice1
Re: Wanting quicker acceleration NC with cosworth Supercharg
Postby Novice1 » Mon Mar 21, 2016 4:44 pm
NitroDann wrote:The rwkw rating is what the engineering papers read, the engineer has no interest in removing your engine and engine dynoing it to SAE specs, he will just write the max legal number and be done with it.
Honestly, turbocharging these isnt that hard, but no one has put their hand up and the cash down yet.
My mechanic looked at turboing my car, lot of stuff would have tobe custom made and he could not do it for budget of $10,000.
NOVICE1
Sailor
Postby Sailor » Mon Mar 21, 2016 5:51 pm
Novice1 wrote:
Dan wrote:As I said earlier:
Dan wrote:The key variable that makes it hard to estimate the power increase when reducing the pulley size on a supercharger is the resulting increase in the intake charge temperature which has a number of impacts including reducing the density of the air entering the engine, possibly the amount of timing that your tuner can run without knock (E85 would help this) etc..
Have you got a dashdaq or something to log knock in your car driving it ok the street?
No i have nothing to log knock.
Novice1
In that case I'm not expecting things to last very long if you keep pushing for more power and upping boost.
Rob
Dan
Postby Dan » Mon Mar 21, 2016 6:35 pm
A 2.5 and cams on the Cosworth would make it a fun street car with all the torque you get from the extra displacement.
Taken from Moto-East "Cosworth/MP62/Goodwin Racing/Flyin’ Miata Supercharger Kit. 2.0 with a 3.1 pulley vs a 2.5 with a 2.9 pulley and very mild cams. 2.5 wins by a long shot, and the cams help the top end breathe instead of having the usual 2.5 fall-off"
Sailor
Postby Sailor » Mon Mar 21, 2016 6:38 pm
You guys crack me up!!
The Cosworth NOW FM (they are the same after Cosworth bailed and FM took over supply) were NEVER designed to give big horsepower.
The system was developed by CW in conjunction with Mazda with the intention of being fitted to the NC in what would probably have been a Mazdaspeed version with just the blower breathing through the OEM exhaust.
It would have been a performance upgrade with good HP and torque increases while driving like one would expect a showroom car...it achieves this very well as my wife who drives ours daily can attest.
It has a smallish air water intercooler which works fine at the boost levels originally intended but suffers when boost is raised to 11psi or so and the car is tracked.
Mazda and CW bailed on the project when they had engine failures which were thought to be strength related..and were to some extent..but were more tune related.
The tune has been sorted and strength improved with a stronger bottom end in later models (2009 on IIRC but someone will confirm this)
The big HP ones you're seeing in the US are NOT early models with fragile innards and most are 2.5l conversions, many with cams.
Advantage of the centrifugal ones is as someone mentioned, is the air to air intercooler which gives a more dense, cooler charge so you get more power with lower boost.
Turbos for RHD are around and making great power but even the best one that claimed be lag free has recently put a little caveat in stating the no turbo system is completely lag free.
Each has it's advantages...if you want a DD with instant boost as the bypass snaps shut..go for the SC. Mine pulls from 1500rpm in 4th WOT with zero knock and 183kW ATW which is rarely if ever used on the road.
I have 3 tunes onboard and am perfectly happy with a slightly less aggressive one in the interest of longevity. One day I'll pull the engine and do a freshen up with forged rods and crank from a later model.
If you're looking for ultimate power or don't mind keeping the revs up all day long go turbo or CF.
Of course there are exceptions to any rule of thumb. Spend up, build a tough engine and SC and you get the best of both, and of course you could do a 2.5 and SC but remember 2.5 won't be legal in NSW because % capacity increase.
Oh and Ron...you really REALLY DO need to monitor knock till you are absolutely certain it's not present whichever way you drive.
I'm not alone in having problems with mine when using cruise on the highway and the cruise applying just a little throttle to climb a very slight rise at 110kph plus.
I found it almost impossible to duplicate manually what happened in cruise.
The amount of KR required at these times was alarming (literally the alarm went off) but was sorted with careful attention by my tuner.
Also make sure you log to see if you are running out of fuel at the top end...Mine was and needed a better pump.
Check also those pesky coil wires as the miss at high rpm and load has popped a couple of engines.
You might also consider having the rev limiter lifted so you don't hit it under high load/boost.....but of course you'll then need to be extra vigilant and stay under where it used to be. A difficult task in 1st and 2nd.
Rob
Dan
Postby Dan » Mon Mar 21, 2016 6:56 pm
Sailor wrote:Of course there are exceptions to any rule of thumb. Spend up, build a tough engine and SC and you get the best of both, and of course you could do a 2.5 and SC but remember 2.5 won't be legal in NSW because % capacity increase.
You can get it engineered though can't you?
I know that >20% larger capacity needs to be engineered but you'd technically need to do for the supercharger anyway.
Novice1
Postby Novice1 » Thu Mar 24, 2016 9:49 pm
Stay tuned, car should be on the market for sale shortly. No parting out.
Have already put down deposit on another car.
Novice1
Postby Regie » Tue Mar 29, 2016 6:03 pm
Whats the new beast Ron?
trickytrev
Vehicle: NC - Supercharged
Postby trickytrev » Wed Mar 30, 2016 6:43 pm
Its gunna be a Billy Cart LOL
Blown 300+
Users browsing this forum: No registered users and 87 guests
