rotrex injector setup NA
trader
Postby trader » Mon Mar 02, 2015 3:00 pm
I have a rotrex intercooled kit running 305 supra injectors. Runs fine (but rich) with stock computer. Next part of the project is to install MS DIYPNP. I have a set of larger RX8 injectors also. My question is would it be of any advantage to run these instead of the supras on a street car bearing in mind it will only be around 7 psi.
NB SE, NA 1.8.
aka_juffa
Re: rotrex injector setup NA
Postby aka_juffa » Mon Mar 02, 2015 3:22 pm
I believe that responses to similar questions suggest that injectors for rotary engines have a different spray pattern and are therefore not recommended for a MX-5 engine.
Edit. Having said that there are a MX5/Miata drivers that are using RX-8 injectors, and successfully from what I read.
J
bartmanftw
Postby bartmanftw » Mon Mar 02, 2015 4:22 pm
I'm using the rx8 ones with no issues. They're just standard denso units so were plug and play and probably have a better spray pattern to the supra ones as they're much newer.
Alex.
speed
Postby speed » Tue Mar 03, 2015 5:33 pm
What Bart said :)
jp928
Postby jp928 » Fri Mar 06, 2015 12:16 pm
Mate of mine has an NA8 with a rotrex on it, up to 10psi. Absolutely stock otherwise - stock injectors, fuel pump etc. Piggy back Xede ecu to control the 5th injector, and 2 switchable ignition maps. Been running 3 years + with no issues at all. 139Kw at the wheels. Runs VERY rich when he stand on the throttle.
jp 92 na6, 96 based Clubbie with AVO Turbo
Users browsing this forum: No registered users and 70 guests
