Hi All,
Anyone here rumming one of these on their cars?
Opinions?
http://www.flyinmiata.com/index.php?dep ... %201991-95
Richard
Flyin' Miata ATI Harmonic Damper
- bear2230
- timk
Re: Flyin' Miata ATI Harmonic Damper
Hi Richard,
I had my rotating assembly balanced and used an OEM harmonic balancer. Those ATI harmonic balancers are meant to be good but not keen on having to "maintain" something like that.
- Hellmun
- Vehicle: NB8B - Turbo
I went the boundary racer pump instead, fixes the same problem and you can run higher oil pressure which hopefully is even better for track work. http://boundaryengineering.com/drupal/node/36. Not cheap though.
- bear2230
Hellmun wrote:I went the boundary racer pump instead, fixes the same problem and you can run higher oil pressure which hopefully is even better for track work. http://boundaryengineering.com/drupal/node/36. Not cheap though.
I was always planning on running with the street/strip pump and the ATI but I'm erring away from the ATI and just running the stock damper now. There must be a good reason that FM use the ATI in every motor they build though and CT is a big fan of them also.
I think full racer pump might be a bit extreme for my car. I will have a talk to Daniel tomorrow and see what he thinks. I have to order some ARP main and head bolts so it is another excuse to take advantage of the Aussie dollar. If the Arias pistons are still a while away I might get the FM Weiscos at the same time.
The oil pump problem can be solved with better flowing relief valve or an external one.
What wozzah said.
Also the race pump is to eliminate pump breakage not improve oil pressure. Also oil pressure doesnt save engines, oil flow does. A stock pump already gives far too much pressure, hence the pump breakage.
- bear2230
OK, Spoke to Daniel and he its says not needed for a street car running 12psi. Also going to use standard main and head bolts not ARP as I planned. Seems that pretty much everything I thought I needed, I didn’t.
Can It be he knows more about engines than me?
Richard.
Richard.
- Hellmun
Sounds good Bear, Daniel is the one building my motor too.
If the flow path size/shape is unchanged then an increase in pressure should see a corresponding increase in flow. I wasn't concerned that stock pressure was low when under load. I figured that the drop-off under high-G braking in pressure would instead change from say 80psi -45psi to say 94psi -59 psi as a overly simplified example.
Users browsing this forum: No registered users and 238 guests
